    Jan 2006
    Cool
    Seeking advice on the proper programable thermostat for my carrier heat pump model 38ycb...I have a honeywell RTH6300b but it says it is not compatable on a heat pump with auxiliary heat....I do not know if I have this...? Thank you for your assistance...
    If you have electric strip heaters, or gas or oil back up, you have aux heat.
    Jan 2005
    Crooksville, Ohio
    The Vision Pro 8320 is a nice stat.
    All Seasons Heating & Cooling
    Jan 2003
    Olathe Kansas
    Check out a W-R 1F85-275. A little cheaper but just as reliable.
    htingky Guest
    depending on furnace type, you can use the carrier thermidisata and receive full benifits of yur 2 stage a/c
