Page 3 of 3 FirstFirst 123
Results 27 to 37 of 37
  1. #27
    Dec 2011
    sandpaper or steelwool
  2. #28
    Jan 2005
    Columbia, Mo GO, TIGERS
    [QUOTE=bja105;11649892
    A flame sensor is just a steel rod with a ceramic insulator, get it reasonably clean and it will work.[/QUOTE]
    Guy I used to work with told me they were in a bind one night, out in the country, rigged in an eight penny finish nail to get them through till morning.
  3. #29
    In a boiler room
    Wire brush followed by a clean rag has always worked for me.
    Keep in mind the burner needs to be reasonably clean as well for good flame signal.
  4. #30
    May 2011
    Washington, DC
    As mentioned, it's said not to use emory cloth or a wire brush because of the possibilities of pitting/scoring the flame rod. It's recommended to use double "00" steel wool pads to clean them. I have also used my sand paper and brushes in a pinch and didn't have a resulting call back. So who knows, sometimes you just gotta do what you gotta do. But to my understanding that is the official recommendation.
  5. #31
    Last month my B-I-L from Salt lake called about his son's furnace short cycling. Told him to clean the flame rod with whatever was handy, such as a dollar bill. Well he called me later and said his son used a twenty so I guess he thought it was 20 times cleaner.
  6. #32
    Virginia
    I have been using sanding cloth for years to clean flame sensors and have not had any problems ,try cleaning the green build up from propane with a dollar bill and let met know how it works out
  7. #33
    Jul 2001
    Central MN and the Twin Cities
    What does it take for you guys to replace the sensor?? I do light cleaning as part of maint..... but if its getting old and the signal is not up after cleaning I replace them. Besides there is a warranty on new parts but not a cleaning of an old one.
    Warning: Just because I am over the head injury doesn't mean I'm normal!
    The day I stop learning.... I'm dead!
  8. #34
    Quote Originally Posted by grasshopper View Post
    How low does the "signal" need to be. Do you take a reading before and after?
  9. #35
    las vegas
    the only failure i have ever found on a flame rod was a broken ceramic.
    i clean them with berryman b 12 carb. cleaner & scotchbrite orange
    pads.
  10. #36
    Jul 2001
    Anderson,SC
    Last year I was using a $20 bill, this year I use a $1 bill. Both work fine. In my dreams I would use a $100 bill.
    STUD
  11. #37
    Virginia
    if it is a no heat service call and you do not have maintenance agreement ,if I have a new one that's what you get if on a tune up I clean it
    hardly ever replaced them on natural gas ,replaced several on propane as propane eats them up
