Results 14 to 26 of 37
11-03-2011, 06:35 AM #14
I haven't done any experiments, but the idea is to not use cut cloth to avoid making small grooves in the flame sensor rod. That's why the dollar bill is used as an example.
I don't clean the spark rod. No need.
I don't clean the HSI type igniter. They can't get dirty.[Avatar photo from a Florida training accident. Everyone walked away.]
2 Tim 3:16-17
RSES Certificate Member
AOP Forum Rules:
11-03-2011, 06:44 AM #15
- Oct 2011
- Dalton, Ga.
- 57
I heard that the flame sensor had little holes in it that would be damaged by sand paper.
11-03-2011, 07:41 AM #16
Professional Member*
- May 2011
- Ripley, WV
- 816
11-03-2011, 09:45 AM #17
Fine sandpaper here.
11-03-2011, 12:52 PM #18
Bingo! The small grooves that are cut into the metal rod by the cut cloth provide a "ditch" for build-up to accumulate in. Over time, this imbedded build-up can become difficult to remove, causing potential nuisance lock-outs. Dollar bills or the "Scotch-Brite" scrub pad (no soap) type material do a good job at cleaning the rod, without scoring/grooving the surface.
A Veteran is a person, who at some point in their life, wrote a blank check payable to the United States of America for payment up to and including their life.
Gene Castagnetti-Director of the National Memorial Cemetery of the Pacific in Hawaii
11-03-2011, 01:59 PM #19
- Oct 2011
- Las Vegas, NV
- 346
Got ya. I was taught to never use sandcloth or sand anything on a flame sensor. The reason I was taught (not sure if it's true, but it's what I was taught) is that the sandcloth scuffs it up too much and tiny pieces of sand stay in the grooves, then when the flame hits it and heats it up it can melt the sand into an extremely thin layer of glass, thus insulating the sensor and getting low microamps. Again, not sure how factual that is, but it's what I was taught and has been the reason I never use sandcloth. I always use a wire brush or steel wool.
11-03-2011, 02:48 PM #20
my carrier tech guy prefers a fine file vs sand cloth/steel wool
11-03-2011, 03:49 PM #21
steel wool gets all over the place though.
i was told the best thing to use is paper like a business card
11-03-2011, 07:57 PM #22
In that situation I would hand the family abrasive cloth, and tell them if they REALLY have to they should use that to clean the ignitor, not a dollar bill.
11-03-2011, 07:58 PM #23
New Guest
- Sep 2011
- Oklahoma
- 5
Gray ScotchBrite fan here.
11-03-2011, 10:05 PM #24
I use scotchbrite or a fine sand paper. My teacher told me about using a dollar bill and I tried it when I first got out into the field and I got a call back. One thing I choose to do is after I use the scotchbrite or sandpaper I take a damp paper towel and wipe the sensor off. You get quite a bit of residue off the rod. I may not need to do this but it makes me feel better.
11-04-2011, 04:59 PM #25
- Aug 2008
- 416
Very fine emory cloth followed by alcohol wipe. Flame sensor was still going strong after 8 years of pre-season cleaning....
11-04-2011, 06:35 PM #26
I have cleaned thousands of flame sensors with aluminum oxide sand cloth. The same bit I use to clean copper fittings. I don't know that any "sand cloth" contains sand. Never a problem with build up or call backs. I clean the flame sensor anytime I work on a furnace, for any reason.
A flame sensor is just a steel rod with a ceramic insulator, get it reasonably clean and it will work.Jason
