    Dec 2003
    Can Manual J be used to size up a radiant floor system?
    Florida
    Manual J tells you the heat loss/gain for an area, and this info can be used to size any heating/cooling system.
    Not so...the potential for downward loss with a radiant floor heating system is great and must be properly analyzed.
    A program design for radiant floor heat is the only program that has this ability...no others will do.
    SW FL
    Thumbs up Floor Heat Losses
    Originally posted by simpleman
    [B]
    Not so...the potential for downward loss with a radiant floor heating system is great and must be properly analyzed. [B]
    Thermal properties of the composite floor and floor heat loss are addressed adequately in a Manual J load analysis if performed by competent, experienced individuals.
    Designer Dan
