Results 1 to 13 of 16
Thread: cogged belts
    cogged belts
    Do cogged belts serve any special purpose are can they be replaced by normal ones ex/ ax45 to a45, stupid question maybe but, I have new maintenance, some units have cogged belts others not and they are same models of units.
    Sep 2006
    Ohio
    Some guys say that X belts grip better, but I feel they tend to slip more due to less surface contact with the sheaves. They have a higher HP rating and don't crack as bad when used on a small dia. sheave.
    Aug 2011
    Indiana
    Quote Originally Posted by iceage View Post
    In a nutshell:
    Cogged belts have slots that run perpendicular to the belt’s length. The slots reduce the bending resistance of the belt. Cogged belts can be used with the same pulleys as equivalently rated V-belts. They run cooler, last longer, and have an efficiency that is about 2% higher than that of standard V-belts.
    Taken From:
    http://www1.eere.energy.gov/industry..._systemts5.pdf
    wedged in freezer shelf
    Alignment tolerance is less for a notched belt other than that they are a better belt.
    Jul 2010
    So-Cal
    They are actually better on smaller sheaves..They contact more of the sheave surface. (Less slipage).
    Landis North Carolina
    Adjustable length/make yourself belts?
    Ive never been one to buy any of the 1 size fits all parts that have been on the market for years such as rescue capacitors and motors and such, not saying I havnt used some with sucess but was wondering if anyone has used the adjustable or build your own v-belts? I was wondering if they really work and do you leave them permanent? It looks like to me its got less surface area to grip. I guess youall know a belt grips on the sides not the bottom, and they look like theres not much for the pully to grab so I would think they would be temporary. Any experiance with them?
    Aug 2011
    Indiana
    Quote Originally Posted by stickinit2thman View Post
    I use these as a temporary replacement if I happen to run out of a certain belt and this particular piece of equipment needs to be up and running NOW. Then it will be replaced as soon as i get the new belt.
    On another note, another tech once told me that he had seen one come in from the factory on a piece of food equipment. Cant remember the manufacturer (maybe hobart?)
    Jul 2010
    So-Cal
    Havent used them...And havent heard anything good about them. most people I'v talked to about them said they dont last long.
    I guess they would be ok temporally until you get the right one.
    Atlanta,GA.
    browning has an app for smart phone ,belt efficiency calculator,for regular belt vs cogged belt
    Apr 2010
    Minnesota
    I prefer the ax belts. They last longer, don't stretch as much as "a" belts, but they wear out pulleys faster.
    Quote Originally Posted by chillerout1 View Post
    That was this link
    Sep 2011
    Vancouver, WA
    Carrier does not use them. They claim they wear out pulleys faster. On jobs I have cogged belts, I'm replacing pulleys and sheaves every 2 years. Thats with a 32nd to a 16th groove worn into the pulleys
    NC
    I've seen these belts:
    http://www.durabelt.com/linkedvbeltinfo.php
    used on heat wheels on ERU's.
