Results 1 to 11 of 11
Thread: Screen Minimum Clearance
    Sep 2003
    Nashville
    Confused
    I want to put up a picket fence to screen the front and right sides of my Rheem 2.5 ton Mod # RRKA-A030JK08E gas/heating electic cooling package unit. What minimum clearances between the fence and unit should be used?
    Thanks,
    Fred
    Louisiana
    3 feet being it's only a fence
    All 3 exposed sides have service pannels. Give 'em room to work.
    burlington county n.j.
    you could probably go 8"-12" as long as fence was easily removed for service. remove it before service tech gets there.
    Huntsville,AL
    use the mfgr recommendations & be legal
    allow someway for servicing, even removal of whole unit.
    Sep 2003
    Nashville
    Thanks for the pointers. Here's what I came up with...
    Clearances on 3 sides are greater than that specified on the nameplate. For unit replacement fence panel at top of pic can be set to the side (by owner, yours truly) by removing 4 SS wing nuts. Space to enter (at bottom of pic) is 28 inch wide.
    This beats tech having to cut thru shrubs with a machete I'm thinkin'.
    Your thoughts????
    looks good from here.
    Beautiful job!
    But where’s the cup holders and the work bench?
    Sep 2003
    Nashville
    Re. cup holders and the work bench...
    I'll get right on that
    Senior Tech Guest
    Nice. I could learn to appreciate customers like you...good perspective on the photograph to, from roof?
    Sep 2003
    Nashville
    Photo was made from deck. My bride nixed the idea of a roof shoot.
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
