Results 1 to 9 of 9
    Oct 2009
    Rhode Island
    Thumbs up you guys ever see this?
    During this summer i went to a call saying that the line was freezing up, i of coarse went thinking it must be the suction line. NOPE it was the liquid line. it was fairly obvious problem though on the account of it was freezing on the out let of the filter drier, i believe the unit was a Goodman and had the spun type of filter drier inside the condensing unit factory installed. any way cut it out replaced with an 083. system worked perfect. its my first year doing this so i thought it was probably a rare thing to happen.
    Philadelphia
    Not so uncommon, Any pressure dropfrom a restriction will be easily found from a temp drop or pressure drop. You got lucky and it was an easy one
    Dec 2010
    Woodbridge Twp, NJ
    See my thread in the WOS entitled "Barking Compressor" that was an example of what youre talking about.
    Every customer you take for granted today will be someone else's tomorrow.
    Sep 2011
    Tucson, AZ
    I had a brand new (within 6 month old) Carrier Rooftop package unit with a plugged filter drier. Replaced it and it works great now!
    Ontario Canada
    It is nice that they are easy to find.....
    Never give up; Never surrender!
    Northeast Wisconsin
    So many manufacturers use crappy and undersized filter and/or driers. Granted, if the system is put together right and clean, it shouldn't matter. But as most of us have found out, that seems to rarely be the case.
    Kenilworth NJ
    I see this on systems installed by the local plumbing contractor. They have a plugged filter drier and soft soldered linesets. Usually they are not so plugged that they Ice up though - that is pretty extreme.
    Hmmmm....smells like numbatwo to me.
    Aug 2011
    sherman tx
    not so rare thats why you look inside unit for factory installed driers .takes a few minutes longer. saves a call back and a frustrated customer.
    Beautiful, Philadelphia, the City of Brotherly Love!
    You have a se5mi common call, that has made me a lot of money over the years.
    In my area 99.5% of the contractors would just add a few more pound of refrigerant.
    The idea of actually disassembling the condenser and removing the mini dryer, seems to be beyond their metal capacities.
    Last month I removed a 5 cu in dryer from a York RTU, and 10 extra pounds of R-22.
    The installer said the unit was a defective lemon (his words on invoice), and recommended replacing the entire unit. This is what I call a CHA-CHING call.
