    Jan 2006
    I need to determine the approximate wire size used in a space heating element (my ancient heat pump). I estimate the length of the coiled element to be approximately 35 inches. The coil is U-shaped with a spacing of 5 inches. The input voltage/current is 240VAC at 50 Amps. The cold resistance is between 10 and 11 ohms on the 3 elements still intact. My best SWAG is #26 but I could be way off base.
    Yup, I know I could take the elements out and measure everything, but that would be WAY too easy. Hopefully one of the HVAC experts out there can provide some input??
    Thanks!
    Lancaster PA
    A. Thats not wire.
    B. Have a contractor come and fix your back up heat for you.
    SW FL
    Thumbs down Way Off Base = Burn
    IF you create a hazard adn burn your house down
    you won't get any in$urance
    now that you notified of your DIY intent to
    ' save a penny, and burn a few $100k'.
    Designer Dan
    It's Not Rocket Science, But It is SCIENCE with "Some Art".
    May 2003
    Dixie
    say it ain't so...am I dreaming or am I imagining what I just read from the OP....man it is to early for this
    Dec 2001
    Chicago, N/W burbs
    if you're getting those ohm readings then there's no need to replace the elements. Have someone come and fix it for you.
    R2B4BTU
    Mod3 Guest
    Unfortunately, due to site rules we as members can not discuss technical issues with the general public.
    Thank you for your cooperation.
