Results 1 to 13 of 20
    Jan 2006
    I have furnace 150'BTU, air input temparature to furnace is 59F, output only 89F, temperature rise only 30F, I can not heat up room temparature more than 64F. Furnace is working on natural gas - burner presure is OK, blower is on low speed. Where can be the problem. Thank You.
    Avon Lake, Ohio
    Furnace is underfired. Have you checked the orifices? Needs to be set up with combustion analyzer.
    captain CO
    Jan 2006
    nozles are Nr.43 original, presure 8.75Mbar like recomended, gas usage in norm. I do not know what I can change.
    Avon Lake, Ohio
    If you have a combustion analyzer and some readings it would be easy to tell you what corrections need to be made, but without that information any changes would not be recommended.
    captain CO
    Jan 2006
    No I do not have CO analyzer, but it is like the air can not take needed heat from exanger and some biger part, than should be, of heat going out with flue gases - vent metal pipe is so hot that drops of water comes to vapour in a blink. may be you know what temperature should be of flue gases?
    8.75 Mbar is equivelant to 3.32 IWC. This reading is the inlet gas preessure or the outlet gas pressure?
    Kansas City
    Actually I think its 3.5, .401 x 8.75 = 3.508.
    Nov 2000
    Eastern PA
    This still could be a matter of too much air.
    What model is the furnace and what does the data plate state the temp. rise should be?
    What type of return? Is the return entering the bottom of the furnace or into one side of the furnace?
    Where are you taking your temperature measurements from?
    There are so many things that can be going on here that we need a lot more information.
    [Edited by RoBoTeq on 01-24-2006 at 09:56 AM]
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    Jan 2006
    What does the burner flame look like?
    Jul 2001
    Slow your blower down.
    Aug 2005
    What color is the furnace?
    eventu rerum stolidi didicere magistro
    Jun 2000
    WYO
    You need a technician to check it.There are too many things that need to be observed in person by a profesional. Make and Model# is the 1st thing.
    never say never
    Do you have an A/C coil on the furnace.
    Call a pro, and he'll be able to take care of your proble.
