mitsubishi city multi fcu help!
Pefy p36 nmhu e
I found the Lev coil faulty and needs to be replaced.
Does anyone know if it can be replaced by accessing the side triangular panel? Or only through the bottom access panel?
Someone had to of worked on this unit. Please help
Just curious
How did you find it faulty if you couldnt access it?
on lg mini splits it can be taken off and replaced by digging and digging until you get to it. Sorry, all those mini splits are so compact its brain damage to get to anything. Mitsubishi is alittle better in my opinion than most the others.
I know its not much help. Sorry! Just take the outer casing off one panel at a time an don't loose the screws!
You can usually find the service manual online and download it for those units just for FYI. Goodluck
1.Removing the LEV.
(1) Remove the control box cover with procedure 8-1.
(2) Remove the fixing screws (four) of the heat exchanger cover
(A), and remove the cover (A).(Fig. 1)
(3) Remove the LEV driving motor with a double spanner.(Fig. 2)
Hope this helps.
Thx all, I used the manual, there is a set of Ohm readings that must be read to confirm proper operations
For the record, a PEFY-P36 is a City Multi 3ton ducted air handler. Not a mini split, which usually is synonymous with ductless one on one systems.
Larger Duct, Larger Duct, More Air, More Air
READ THE MANUAL
What if I train them and they leave?
What if you Don't train them and they Stay!
DSG member
the side panal is where you access the LEV motor not a hard job
- You may not post replies
- You may not edit your posts
Forum Rules
