Page 1 of 6 123456 LastLast
Results 1 to 13 of 78
    Oct 2011
    Baltimore
    2 condensers, one evaporator
    Can I replace a 10 ton single circuit, AC only condensing unit with two 5 ton split systems condensers?
    I have a situation where I cant replace the existing R-22 evaporator and a R22 condensing unit is not available.
    I plan on running the units in tandem. What controls should I have to make this work? How can I ensure proper and equal oil return? The old unit is 230V 3phase, 5/8 LL and 1 3/8 suction line.
    Any input would help.
    I wouldn't. Get a matched 2 circuit coil. Otherwise, may have to use solenoids or checkvalves to aim refrigerant the right direction.
    Jul 2001
    maryland
    Buy a Goodman 10ton R-22 condenser.
    Saving the world...one service call at a time.
    Mesquite Tx.
    One of the compressors will end up with all the oil. Then you know what happens to the other one.
    Nos operor non pensio volutabrum
    MEXICO
    the dual-circuit evaporator?
    Dec 2010
    On a Peninsula in NE NC
    you can replace it with 2- 5 ton systems twinned into the same duct.
    It's hard to stop a Trane. but I have made one helluva living keeping them going.
    Oct 2011
    Baltimore
    Checked with Goodman he in MD. No 10 ton R22 units available. The evaporator I have is a 3 circuit horizontal coil in a section of duct being used for a process. Changing that coil is not an option at this time. I'm thinking if I split the piping even between the two units, put check valves in the liquid lines, and install crankcase heaters, this might work. If only I could install a oil equalization linebetween the compressors.... Thoughts?
    Kaufman county, Texas
    I am having a hard time believing you cannot get a 10 ton condenser, might need to make some more calls.
    If you really cannot, can you repair the old one in any way? What is wrong with it?
    "You boys are really making this thing harder than it has to be". Me
    "You are long on mouth and short on ears" John Wayne
    "I say we take off and nuke the entire site from orbit. It's the only way to be sure." Ripley
    Service calls submitted after 3PM will be posted the next business day.
    I give free estimates [Wild Ass Guesses] over the phone.
    My front door is locked. For your personal protection.
    Jul 2001
    maryland
    Quote Originally Posted by FitterTom View Post
    I JUST BOUGHT ONE about three weeks ago.
    Call the Capitol Heights branch.
    MEXICO
    which is the current model or brand of your machine?
    Please don't do it. Please don't try it. You will give HVAC a bad name.
    Customer WILL HAVE to spend the money. Else, back off.
  12. Dislikes Johnny P. Lira disliked this post
  13. #12
    Oct 2011
    Baltimore
    Wow. Goodman in Frederick has a 10 ton condensing unit. I checked a few weeks ago and none were available. Problem solved, thanks.
  14. #13
    Mar 2016
    I don't think so
    Seems to me the oil in the crankcase, "of the one which doesn't run while the other is running", in case that were to happen due to some breakdown of some kind, I assume that's what you have to be talking about, would actually stay in the crankcase due to valves and such, It's not going any where, as long as one compressor is running then oil is being distributed and once both start running again the oil would distribute through the entire system and would eventually balance back out. The only reason you see oil lines shared on tandem compressors is so this issue with the oil can equal out faster and smoother.
