Results 1 to 13 of 17
    Oct 2011
    Carrier 30RBA160 not staging up
    Hi, need some help here, since Carrier has washed their hands of this problem, I have a 30RB160, 2005, I need to change 1 compressor [again] and need to disable the "A" circuit to work on it, when I do this, "B" circuit will not stage up and maintain water temp, only 1 "B" compressor comes on with Hot Gas, and just runs forever, no other compressor{B circuit} will stage up, I've done this in the past and never had a problem with "B" cuircuit staging up and controling water temp. I've tried to stage on Circuit "A" just to see if I can do that, and it works perfectly. Carrier has asked me to do several things to it and still doesn't work, [so many, I can't name them here] I've had to replace so much on this machine, I wish I could trade it for something else. The last response I got from Carrier was,"We don't know why it's doing this, Sorry" Any help would be greatly appreciated. Lonnie
    East of big city prices.
    Are there any override modes on preventing it from loading up? Has any software been upgraded? Power problems ? Why are your compressors failing , contagious welded?
    Greenville SC
    I had one do this and I downloaded a new program into it. Solved the problem, at least on this occasion.
    Greenville SC
    The chiller will also run much better with the latest and greatest progam.
    Oct 2011
    Thanks for the replies. No override modes. Don't know reason for failures, but thinking ,like was suggested, need upgraded version and maybe will solve problems, not all the same problem with compressors, 3 were vibrating so bad, it broke the discharge line twice, 2 were shorted, the rest just locked up. Will see if Carrier wan't to talk to me to upgrade my software. Thanks. Lonnie
    Quote Originally Posted by 2wings View Post
    What be the serial number on this machine?
    Oct 2011
    Serial Number=4005Q80419
    What does your phase monitor look like?
    Oct 2011
    No phase monitor.
    No phase monitor.
    Unless someone took it out it's in there somewhere if not I think we found your problem.
    Oct 2011
    Unless it's built into one of the circuit boards, I don't see it, this was low bid, so if they could leave something out, they might have done that. I'll look again. Lonnie
    Greenville SC
    It's in there. All the RB's have one.
