Results 14 to 19 of 19
    leland nc
    wow hit the valve and it works
    now hit it and it closes
    if the valve sticks closed there is a good chance it will stick open. this can be a very dangerous situation you have going on here. how do you know it is fully open. can you trust it. what is your families safety worth
    call and get a tech out to fix the unit
    Nov 2007
    Unhappy Heil 867.769437, Manual for NUGK100DH08
    help please. We bought a house with the Heil furnance but no instruction book to go along with it
    We see water connections to it so we are assuming it has a humidifier but are not sure.
    Would anyone by chance have the manual for this unit? I would be very appreciative. Thank you.
    Manual
    We do have the manual for ours. What are you looking for. A humidifier is not built in. It should be external somewhere else on the system.
    Nov 2007
    manual
    i'm looking to get a copy of our manual. On the top of our unit is coils (kind of like a radiator (they are all in a row and look like upside down u's) and there is water line to the radiator. That is what makes me think it is a humidifier on it. Unfortunately we were not left with any manuals and i've been pretty lucky in finding the stuff online except for this. They have a emerson air cleaner attached to the side of the unit but it is the water going into the furnance that has us stumped.
    Jun 2001
    Louisville, KY
    Picture is worth a thousand words.
    Minnesota
    Quote Originally Posted by dawnjuneau View Post
    The coil you are talking about is the other half of your air conditioner system. Your furnace is a condensing furnace, meaning your combustion exhaust cools to the point of condensation. The condensate has to be drained away from the furnace. Often on a furnace of that age, the leaking is caused by a cracked heat exchanger. You'll want to call a service professional and rule out a cracked heat exchanger, which could be a potentially dangerous situation.
    White Bear Township, Minnesota
    www.summitheating.com
