Results 1 to 7 of 7
    I FOUND THE CIRCUIT WIRING DIAGRAM WHITCH IS STICKED ON THE BACK OF THE FRONT PANAL IS WRONG. ON THE DIAGRAM,THERE IS A WIRE CONNECTED BETWEEN CM/T7 AND TC/COM WHITCH WOULD SHORT HPS AND LPS.THIS WIRE ACTUALLY GOES FROM CM/T7 TO TC1/COM, THERE IS NO DIRECT CONNECTION BETWEEN CM/T7 AND HOT LINE. THIS TERMINAL CALLED TC/COM DOES NOT EXIST AT ALL,AND THE CONNECTION BETWEEN TC1/COM AND HOT LINE DOES NOT EXIST EITHER.
    Jul 2005
    Please stop with the yelling already... :-(
    Jun 2001
    Louisville, KY
    Please quit yelling...
    Relax nisong ... If there is a T10 and T11 and your CM, then it has been replaced and the new one is wired different from the original. There was a problem with the bypass relays on the original ones.
    It does not have T11 and T10, so it must be original.Since it was installed,this unit rans for a few days then stop by itself,has to be reset to start.Replaced all controls except bypass relay,it remaines the same.
    [Edited by nisong on 01-20-2006 at 11:37 PM]
    May 2005
    Calgary, Alberta, Canada
    OMG who is paying the bill on this?
    Yes we have air conditioning in our igloos.
    Nov 2005
    Chicago
    30GT
    NISONG
    If this unit has a FloTronic computer driving, the random stopping doesn’t surprise me.
    We have a 30GT080 that has a mind of it’s own on occasion.
    The last time we had a problem the computer data said the unit was running but no compressors where running. I changed the two contactors on the 40-ton compressor and have not had this problem lately. This computer is quit sensitive to RFI per Carrier.
    cvw
    [Edited by cvw on 01-24-2006 at 07:29 AM]
