Results 1 to 13 of 13
Thread: Stumped
    Jan 2006
    Question
    Trying to repair a Lennox G26 with intermittent pilot ignition. When igniting, I get spark but it acts like it's not getting gas, or that there's air in the line. The ONLY thing that works is to take off the combustion box cover. Then the pilot lights with no trouble. Here's a list of what I've done so far:
    Cleaned/replaced flame sensor
    replaced ignition module
    replaced control board
    cleaned pilot valve and orofice
    checked for proper voltage to pilot valve, main valve
    checked for gas flow from pilot valve
    disconnected intake pipe- makes no difference
    pressure switch is good
    I suspect a crack in the heat exchanger even though I don't see any evidence of that. I have seen 80% furnaces with a crack near the burner and it disrupts the flame, but preventing the pilot from lighting?? Removing the intake pipe makes no difference. Only taking the cover off the combustion box. If the exhaust is plugged, the pressure switch would prevent any ignition at all.
    Would really appreciate some good advice!
    Jul 2003
    try checking the pilot gas pressure. Is this a propane fired unit? tank pressure can change. If you live in a cold climate check the gas regulator outside for proper venting. I have seen ice block the vent and cause pressure problems.
    Register as a pro, were not allowed to answer questions like that in the resi forum.
    Nov 2001
    Are you sure it's a G26,
    I saw most to have a hot surface ignitor.
    If you try to fail, and succeed.
    Which have you done ?
    Apr 2003
    Eugene, Oregon
    Birds
    Proud supporter of Springfield Millers and Oregon Ducks.
    burlington county n.j.
    original g26 heaaters had that pos johnson blue box.
    heat&blow is offline Professional Member-BM-bad email, server rejected
    Jan 2006
    Rubber gasket where the the pta assy, goes it isn't air tight, make sure the plate of the comb. Box is in properly and tightened, make sure the pilot assembly is tightened on the burner holder evenly. And there is most likely a crack in the h/e on the top part about half way in, good luck
    leland nc
    there is a screen where the intake pipe comes into the burner box. more then likely it is covered with debree
    Had this happen to a couple of units, but intermittently, when the G26 first came out. Failure to light pilot one out of maybe ten trials. After trying some of those other things I replaced the pilot assembly. That did it. Not exactly sure why.
    Jan 2006
    Thanks to all for the advice. The customer put me off until Monday, so I'll let you know what happens.
    Jan 2006
    Finally figured it out. Tried to adjust the pilot pressure and nothing happened. Replaced the gas valve and it works fine.
    Jan 2006
    Question
    its been awhile since ive worked on res equipement.if it pvc exhaust pipes try reducing air intake.like from 3 to 2 at termination.or play with it with a piece of duct tape over end of pipe ,to see if this would help.
    Due to our Forum Rules we are not allowed to discuss step by step instructions or repairs in this area.
    If you are a professional in our field please register as such and fill in your credentials. We can discuss technical issues only in the Pro Forums.
    thx
