Results 1 to 13 of 15
Thread: New Tech
    Dec 2010
    New Tech
    Can someone explain me what dose btu stand for in Cooling and heating.
    Sep 2009
    Stumptown,USA
    British Thermal Unit. The amount of heat energy that it takes to raise one pound of water one degree Farenheit. Wikipedia might go into more detail.
    Challenge yourself, take the CM test --- Certificate Member since 2004 ---Join RSES ---the HVAC/R training authority ---www.rses.org
    Jul 2010
    Denver, CO
    Paul Bee is right on the money. We use BTU's to describe heating capacity and cooling capacity. In heating we are adding BTU's to our conditioned space and in cooling we are removing BTU's from our conditioned space. This is the basis of a huge part of our industry and the BTU is widely used in America. The metric equivalent is the Joule but we don't have to worry about that, yet. When I was first trying to wrap my head around a BTU it was described to me that a BTU is about the energy in a match, it helped put it into perspective for me. So perspective a 100,000 BTU/h furnace is some what equivalent to burning 100,000 matches per hour.
    Southeastern Pa
    I never heard the match analogy. Neat.
    Are you in a training program?
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Mar 2009
    Mid-Mo
    Quote Originally Posted by HuNGRYTeCH View Post
    Love the match analogy. The thought of converting to the metric system in our trade makes my head want to explode. I don't know what I would do...I guess buy a lot of digital gauges and switch it to psi!
    Jul 2010
    Denver, CO
    Yeah I am. I take night classes at a community college, going for an associates degree in Commecial HVAC. I learned this years ago though, before I started school when I could not wrap my head around BTU ratings.
    We need more abbreviations/acronyms in HVAC, at least another 60 or so.
    BTU
    ASHRAE
    AHRI
    SH
    SC
    Delta T
    Delta P
    T
    Q
    GPM
    We just don't have enough yet.
    Remembering that BTU is British Thermal Unit wasn't the hard part. Remembering how little a pound of water is was.
    Mar 2009
    Mid-Mo
    BTU
    ASHRAE
    AHRI
    SH
    SC
    Delta T
    Delta P
    T
    Q
    GPM
    Work for a company that does government work and you will have all the acronyms you can stand in addition to the ones in the trade!!! Ugh, government alphabet soup...
    May 2003
    Utah
    While this might give some real life perspective as to the relative amount of heat that can be assigned to 1 Btu, I'd be very surprised if there was enough heat content in a single match to raise 1 lb of water 1*F.
    Jul 2001
    Canada
    I'd be very surprised if there was enough heat content in a single match to raise 1 lb of water 1*F. Let alone a match that burns for 1 hour.
    May 2003
    Utah
    Actually, there is no time frame for raising a lb of water 1*F.
    1 Btu is simply the quantity of heat necessary to accomplish that increase in temperature, regardless of the time it takes.
    1 Ton is the amount of heat transfer necessary to convert 1 ton of water at 32*F to 1 ton of ice at 32*F, in a 24 hr period.
    One Ton = 12,000 Btu/hr
    Feb 2007
    Helena, Montana
    Depends on the size of the match!!!
    Don't worry zombies are looking for brains, you're safe...
