    Oct 2011
    Bad heat pump or thermostat?
    I have a Rheem heat pump (RPNE-030JAZ) that has started working in a random fashion. What would cause the heat pump to run for 2-3 minutes than shut off only when I reset the thermostat (white-Rogers IF73)? I thought it might be the thermostat but when I switch it to emergency heat the gas furnace runs fine. Thanks in advance for any thoughts.
    Maybe its going into defrost.
    Massachusetts
    Methinks you need a visit from your friendly service tech to check the operation if it's not operating as it has in the past.
