Results 1 to 7 of 7
    Jan 2001
    working on a commercial weil mcclain boiler. it is to be set at positive .2 at breech damper. my question is what should the reading on smoke pipe between breech and draft regulator be set at(what should i set draft regulator at??)
    Nov 2003
    Boston
    H,
    I may be misreading you post, but,
    Your question implies that you are not a burner tech (neither am I).
    If you have to ask a qustion like that than you should not make any adjustments to the burner or breeching, could be very dangerous.
    If your legit, try posting over
    here
    powerhead
    [Edited by powerhead on 01-17-2006 at 11:20 AM]
    Edited by powerhead on more than one occasion
    Apr 2005
    where the beer flows like wine
    size and fuel type?
    Lancaster PA
    You'll find that info in the install manual.
    Keep in mind, that after the breech damper, the flue pipe draft is no different then a neg pressure boiler.
    Mid-west
    Go to the Bacharch website they have alot of combustion testing info
    Nov 2005
    Like onetime said.
    You have to look at the whole picture when you start
    adjusting air/fuel ratios on burners. It's the difference
    between a clean flame, and CO.
    You need to look at stack temp, and combustion gas
    composition while making adjustments. Get the whole
    picture BEFORE you make adjustments.
    Regards......
    Nov 2003
    rhode island
    draft at damper breeching ,,taken at 1/4 in plug should be .01 positive ,in stack ideally should be .04 negative, positive pressure should be abtained by damper closure ,,,,very inportant CHECK overfire pressure dont exceed factory recomendations
