Results 92 to 104 of 113
Thread: Cracked heat X ????
12-28-2011, 11:04 PM #92
12-28-2011, 11:23 PM #93
Professional Member*
- Dec 2011
- PA
- 98
12-28-2011, 11:26 PM #94
- Dec 2011
- somewhere between here and there
- 458
lol...loaded question
but yes... i do carry my co detector into every job.....responses from homeowners vary, but most are impressed
Please, Please Please......keep the Factory Smoke in the Wires!!!!!
Is it Rum'Oclock yet???
12-28-2011, 11:38 PM #95
12-30-2011, 10:01 AM #96
What type of heat exchanger is it? When you open up the supply duct and look at it are the seams folded and welded. Because those particular H/E are tanks and seem to last. With a bore scope through the burner section they look cracked but indeed they are not.
I agree no visible crack or hole = No red tag
12-30-2011, 05:29 PM #97
- Jul 2010
- nebraska
- 1,231
Got a perfect example of why that's important today. Lennox G20 that another company replaced the heat exchanger last year. It had the typical stress mark and rust line along the back but passed water test. Cleaned the burners,crossovers,pilot assembly and flame sensor then put it back together to get some flue gas readings. Stuck the probe in the flue and had 4.2% O2 and over 9000 ppm of CO,I know should have pulled the probe out way before that to save the sensor. Gas valve was cranked all the way in and reading 7.2", backing it out didn't change the pressure. Installed a new gas valve and made a new sheet metal flange that the bone heads left out. CO 14ppm with 7.2 O2 after fixes.
01-04-2012, 08:52 PM #98
- Dec 2011
- PA
- 98
7.2"!!
I had a tech once turn one down to 2" while I was away... I got back and asked why so low and he replied that is where it needed to be in order for the burners not to snuff out...
Not quite sure what the hell he was thinking there...
I told him to come with me and it turned out they weren't snuffing at all but they cutting out from the rollout sensor. Old Bryant 80% rooftop unit with just about everything rusting... gave them the option of repair or new unit, they took the new unit
01-08-2012, 03:21 PM #99
- Dec 2011
- PA
- 98
01-08-2012, 03:41 PM #100
- Dec 2003
- 2,068
Has anyone anywhere found a home with carbon monoxide in the living space, and the cause was a small crack in the furnace heat exchanger? If so Id like to hear the details.
On any residential co problem, Id put my money on a vent problem. Spend more time inspecting vents...
01-08-2012, 03:53 PM #101
- Dec 2003
- 2,068
Another question. Has anyone anywhere found a home with co in the living space and it was casued by a gas pack?
01-08-2012, 03:54 PM #102
01-08-2012, 03:56 PM #103
- Dec 2011
- PA
- 98
Actually, out of 4 calls this month I had 3 homes reading anywhere from 3-9ppm and 1 reading above 20ppm(shut furnace down before it got any higher). Out of those 4 two had cracked HX's. The one with 20ppm+ was carbon build up in the HX and the exhaust, customer upgraded anyway. The last one had a bad inducer assembly.
01-08-2012, 03:58 PM #104
