Results 66 to 78 of 113
Thread: Cracked heat X ????
12-09-2011, 06:49 AM #66
Depends, did the draft change? If not, yes. Even with the different fan speeds, that usually only correlates to a 100-175 degree flue gas difference... But it's still going to be over 270 easily, usually much higher. Water doesn't condense, at this pressure, until 212 degrees so it isn't condensing in the hx. UNLESS there is insufficient venting of the flue gases allowing the to cool in the flue and hx after shut down... This is also why you get rusty and soft flues
The fix for ND furnaces is slightly different than what I listed before
12-09-2011, 09:23 AM #67
sure it changes but its not the on cycle draft i'm concerned with but what happens between the time W terminates and stack effect no longer takes place. i've removed different amounts of heat from the heat exchanger at the end of the heat cycle by virtue of moving different amounts of air across it.
i was born under a wandrin star.
12-09-2011, 09:29 AM #68
....so youre saying the flue stops drafting immediately after w no longer receives a signal?
your thought process isnt complete. the flue will still be warm for some time and there for stack effect will continue..again, you have to make a repair, (connecting the flue to the furnace) but that will stop it. take a look, when you see a rusted hx youll also usually notice a replaced flue or rusted flue.
they are hand in hand
12-09-2011, 11:54 AM #69
no, just the opposite. i'm saying the flue will draft differently at the end of the heat cycle in each of those three conditions. if you agree what would be the effect on moisture retained in the heat exchanger?
connect the flue to the furnace? um.....ok but thats not a variable in my analogy.i was born under a wandrin star.
12-09-2011, 12:05 PM #70
12-09-2011, 12:06 PM #71
it should be, thats why they rust out, natural draft furnaces have unconnected flues...while draft will decrease as the flue cools, it will still continue to draft for some time. this will remove any gaseous moisture in the hx...before it has time to condense...but you have to have a connected flue to do that...something ND furnaces dont have without modification
12-09-2011, 05:36 PM #72
- Jan 2007
- Mn the state where absolutey nothing is allowed
- 1,086
12-09-2011, 11:31 PM #73
in one condition "low speed" as compared to high speed. the heat exchanger is nominally hotter at the time "w" terminates (its been running at a higher heat rise). the airflow across the heat exchanger is removing less heat from the heat exchanger during the time the fan runs before cycling off because less air has moved across it and at a lower difference in temperature. the stack effect is in effect longer and at a higher temp before cooling in low speed.does this have no effect on the moisture retained in the heat exchanger?
12-10-2011, 10:45 AM #74
12-10-2011, 11:29 AM #75
well i can only defend what i said. i declined to go off topic on the furnaces i've seen vented to brick chimneys, the use of a draft gauge, curtain effect, barometric dampers, blocking off the draft hood (whatever phrase for that you prefer) etc,etc. my point was on eggshell metal, my observation about heat rise "often" is valid and i'll continue to correct it as needed when i pull cold sweaty furnaces into the maintenance pool. profound venting problems not withstanding. i have you down as a no to my question.
12-10-2011, 11:41 PM #76
- Dec 2011
- bedford ind
- 1,080
heil is ICP. Look for little round metal rings that might be laying in the furnace. These pop off sometimes, usually due to overheated hx.
12-21-2011, 07:35 PM #77
- Dec 2011
- Georgia
- 18
The best way to identify a cracked heat exchanger is with a combustion analyzer. with gas pressure set at 3.5 for natural and 10-11" w.c for lp. you'll notice a rise in co when the blower comes on. a drastic rise. you don't need to pull it out or anything. if it is rusting that indicates there has been a problem for a long time. What type of furnace is it?
12-21-2011, 08:11 PM #78
