Results 1 to 6 of 6
    Oct 2011
    Colorado
    multiple proposals - mismatch outdoor unit & coil
    Hi all- I am getting bids to replace my furnace and A/C, and have received multiple. The proposed vendors are Lennox, Amana, Rheem and American Standard.
    Two of the companies have proposed using a 3.5 ton A/C (outside unit) with a 4 ton coil with the furnace. Both have indicated that this will provide greater efficiency.
    It is interesting to note that in Colorado that Xcel Energy provides tiered rebates for replacing the A/C with a newer and/or more efficient system - but they specifically exclude any rebates for mismatches as described above.
    Can anyone provide comments on the benefits or deficiencies of such a combination?
    Many thanks for any feedback.
    Feb 2011
    North East Ohio
    That isn't a mis-matched system automatically. Look up the combination on AHRI directory and see if it is a good match. We regularly put a larger evap coil on a system for efficiency reasons. Especially with R-410a. Good luck
    burlington county n.j.
    Quote Originally Posted by NCHeat View Post
    this has been done for many years.
    as long as its an AHRI rated match you're good to go.
    Jun 2009
    Albuquerque NM
    I'm not a pro* so I can't give advice, but if I got such proposals and had your concern, I would ask for the ARI certification numbers for these combos. I have a 2.5 ton condenser with a 3.5 ton coil and it is a ARI match.
    Jun 2011
    Wake Forest, NC
    Quote Originally Posted by garya505 View Post
    Hypothetically speaking, of course.
    It's not rocket-science...
    It's electromechanical thermodynamic engineering
    So Cal, Maui, & Kauai
    Many manufacturers don't have 1/2 size coils so a 4 ton coil IS a match to the 3 1/2 ton condenser- especially Rheem.
