Results 1 to 13 of 25
    Oct 2011
    Is this noise coming from my Heat Pump normal?
    Hi,
    Is this start-up noise coming from my Rheem 13PJL30A01 heat pump normal? It makes the same noise is heat or cool mode.
    Here is a link to a Youtube video.
    http://www.youtube.com/watch?v=FkeTik1sU5E
    How old is the unit?
    Oct 2011
    It's a few months old.
    Aug 2011
    Lewes, DE
    some what normal. having a Hard start kit would help the system noise and life...Youre hearing the compressor trying to overcome inertia
    Scroll compressors do make that noise on start up.
    I'd have the installing contractor come out and give everything a once over to make sure
    Oct 2011
    south al.
    thats pretty standard, a hard start kit may reduce it some. some of the higher efficiency units come with an insulated blanket around the compressor which helps to dampin the noise. you check to see if rheem can supply a blanket or you might be able to build something. good luck!
    Oct 2010
    AZ
    Your heat pump barks?
    Southeastern Pa
    YES. It IS normal.
    NO, a start kit will not change this. The sound is the scrolls beginning to turn. It is not so much a matter of inertia, as it is a matter of the scrolls loading up and moving to the position they will hold under load.
    No reason for concern.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Southeastern Pa
    Quote Originally Posted by mlc1955 View Post
    The last thing I would do is advise a home owner to get into the condensing unit and try and wrap a compressor. This raises issues of dangerous voltages and spinning fan blades.
    Will you or I be there to make sure such a person is safe while doing that?
    Nope.
    For that reason, a pro could install a blanket on it, but I don't believe one is needed.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    leland nc
    never heard a scroll compressor bard before
    it sounded normal you could ask you contractor about a sound blanket on the compressor
    mat be a few bucks more but will make a big differance
    Sounds normal to me too.
    In an area that doesn't go below freezing?
    Aug 2011
    Lewes, DE
    That is breaking inertia...
    Quote Originally Posted by tinknocker service tech View Post
    some of the newer rheem/ruud heat pumps don't use a contactor...
    but this is a discussion for a different area.
    and yes, a compressor blanket can make a difference.
    also, if there aren't vibration isolating pads under the condenser, they can aid in noise reduction as well.
