Results 1 to 9 of 9
    Oct 2011
    Carrier coil CE3AXA060 5TON Can Accurater be replaced with TXV?
    If so, does anyone know of a part number that will work?,
    Thanks,
    Mike
    Dec 2008
    Ontario Canada
    Quote Originally Posted by mfilli View Post
    Thanks,
    Mike
    please note this is not a DIY site, but as an AC and Ref mechanic, i am very curious, what is an "Accurater" and where is one found on your carrier coil?
    Jun 2006
    Richmond, VA
    Quote Originally Posted by LKJoel View Post
    Fancy name for a piston....
    1. "your ductwork is too small"
    2. "your system is too big"
    3. "You Need a New contractor" Your's might be okay, but if it's not ME working on your system-your contractor must be a loser-I can see it from here.
    Dec 2010
    Quote Originally Posted by beshvac View Post
    Correct and yes, you can remove it and install a TXV.
    Dec 2008
    Ontario Canada
    never heard it before, does is it refer to a brand of piston or a style of piston, is it a technical name?
    Jul 2005
    It's the Carrier trade name for their "piston metering device". The only thing special about it is that the design is specific to Carrier Enterprises. IOW, you couldn't put a Carrier piston (AccuRater) in a Trane piston body, or vice versa.
    Jun 2011
    Houston area
    Quote Originally Posted by hvacrmedic View Post
    No, they are not interchangeable. And yep, an "AccuRater" is an acronym for an "accurate rate" orifice and it's just Carrier's lingo. I can remember AccuRaters as far back 1980, maybe earlier. And for any AC evaporator coil you can remove the orifice and use a TXV.
    The picture in my avatar is of the Houston Ship Channel and was taken from my backyard. I like to sit outside and slap mosquitos while watching countless supertankers, barges and cargo ships of every shape and size carry all sorts of deadly toxins to and fro. It's really beautiful at times.....just don't eat the three eyed fish....
    LMAOSHMSFOAIDMT
    Dec 2008
    Ontario Canada
    interesting, thanks for the info, did not know that
    and make sure you remove the piston as on the carrier you can install the txv with out removing the piston
