Results 1 to 13 of 14
Thread: Trane?
10-10-2011, 03:09 PM #1
New Guest
- Oct 2011
- 5
Trane?
M father has a Trane Model #TTL742A100A0 Serial#C13226568 and has had it since 1988. He would like to know the ton that it is and what similar one to replace it with? Thanks for anyones help with this!!!
Oakey
10-10-2011, 03:20 PM #2
Professional Member*
- Mar 2010
- Manassas, VA
- 61
It is a 3-1/2 ton unit.
10-10-2011, 03:23 PM #3
Don't do
anything until you get a load calc done on the house.
GO NAVY, BEAT ARMY!
A DECADE OF DOMINANCE! +1
10-10-2011, 03:46 PM #4
- Feb 2009
- Portland OR
- 1,509
Im sure a lot has changed on the house since 1988 and im assuming the sizing of the air conditioner at the time may not have been done at today's standards. While you can sometimes replace an air conditioner with a like for like unit(size wise) that is typically not the correct way to do it as the house may now have more insulation, trees may be shading south and west facing windows now and air conditioners used to be commonly oversized. Oversized units cost more, perform worse, and have a higher probably of breaking down while not dehumidifying as well.
Check out my YouTube channel - http://www.youtube.com/user/skyheating1 We have customer testimonials, product reviews and more!
Like us on FACEBOOK if you like our advice here!
10-10-2011, 07:49 PM #5
New Guest
- Oct 2011
- 5
House has not changed any actually, he is looking for another ubit since it is getting kind of old and while he still has the money. Thanks for the many replys
10-11-2011, 09:41 AM #6
New Guest
- Oct 2011
- 5
bump
10-11-2011, 09:47 AM #7
- Mar 2006
- The South
- 1,848
Oakey
What is Father's location?
This is AC or heat pump?
Condenser is paired with air handler or furnace?
Post back.
IMO
10-11-2011, 11:40 AM #8
A TTL is a straight AC condenser. Which I believe is probably a typo and is supposed to be TTR
To the OP (doke) you should have a contractor run a load calculation on the building to determine what size replacement system is needed. Often times a replacement system is smaller than the original as the original is too big, which cause extra energy consumption, and poor humidity removal.
A comparable replacement trane system would be in the XR line, or you can go higher efficiency and a lil better warranties with the XL line of equipment.If Guns Kill People, Do Pencils Misspell Words?
http://www.youtube.com/watch?v=nFl0n...ture=endscreen
10-11-2011, 11:55 AM #9
New Guest
- Oct 2011
- 5
this is just an A/C outdoor and is in a very well upkept doublewide Trailor A/C is outside with the heatpump on the inside were the filters are approximately 1800 Sqare feet and model # did begin with TTL ust lookin fo another trane model comparible so no one gets over on them sayin they need more than what they already have. Seems like in the summer months it never shuts off and he has it cleaned. Thanks for all you guys help I really appreciate it!!
Oakey
10-11-2011, 12:51 PM #10
the electric heat is inside. A heat pump system would be best for replacement.
I would install a package heat pump if it where mine to do.If Guns Kill People, Do Pencils Misspell Words?
10-11-2011, 08:31 PM #11
New Guest
- Oct 2011
- 5
bump
10-11-2011, 08:57 PM #12
please follow the site rules
if you have further questions we will be happy to anser the best way that we can.12. Do not double post or bump
Choose the correct category or section for your thread and put it in only one category forum. Also, if your thread has not received any new posts lately it will slide down the list, so be it. Do not post a reply just to bump it up the list.
As far as i can see, this thread has come to a conclusion at this point.
10-12-2011, 04:11 AM #13
- Mar 2006
- The South
- 1,848
Oaken
Just to be clear, what is your location?
You plan to replace both outside condenser and inside air handler for a complete matching system?
You are heating now with a heat strip? If so, do you know the size of the heat strip?
Depending on your location and winter climate, a heat pump system may be a better longtime choice than a straight AC system with strip heat only.
Post back.
IMO
