Results 1 to 12 of 12
Thread: Pressure Switch
    Oct 2011
    Pa
    Pressure Switch
    I helped a frend of my sons install a mod # h9mpd100j14c2 100,000 btu, diagnostic code ( Pressure switch open when should be closed) the switche is good . the combustion motor is good. I'm havinga hard time fixing the error can any one help me with this. I remove the vent pipe and the heater worked ok, all the vent pipe is new. What could my problem be ? Horizonal Left thru Top
    You answered
    Quote Originally Posted by bIGEARL721 View Post
    your own question
    Oct 2011
    Pa
    The Diagnostc code keeps on show pressure switch the switch is good , combustiion motor is good and the exhaust pvc is new.
    Oct 2011
    Pa
    I did ?
    Feb 2007
    Oct 2011
    Pa
    How did i answer my own question ?
    In short did you not say error code but you could make work?
    Oct 2011
    Pa
    Yes, by removing the exhaust vent, it wili fire up
    Hmm
    Without giving you DIY that every one can read and not trying to sound condescending but think.
    las vegas
    rtfm
    Oct 2011
    Pa
    I could be, I found the problem
    Southeastern Pa
    You should call a pro who can give info in person and help you correct the underlying cause of what that switch is telling you.
    We cannot give DIY info on this site.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
