Results 1 to 13 of 13
    Oct 2011
    33 inch York /Luxaire flame rod R & R suggestions
    Wondering if any one wants to share their method and tools of choice for getting the flame sensors in and out of these York 33 inch furnaces.
    For such a common part thats needs attention most often , it is now a real pain to get out and back in .
    Ontario, Canada
    The Lennox G61 series is another tough one. Unless your a smurf! Best tool I have for these is patience. Takes less time to remove some parts to make room, than trying to force it and break something.
    Apr 2001
    Quote Originally Posted by CELSIUS View Post
    You are right. I don't know much about the York or Lennox, but the Carrier 90's are ridiculous if the gas and intake come in from the left. I'll remove the gas line and cut the PVC, and be done faster than if I had tried to work around them.
    The one part that needs service the most is the hardest to get to!
    I bought this PVC cutter that cuts 2", it gets in tight spots, doesn't need a cord, and leaves no shavings or burr.
    http://www.amazon.com/Black-Rhino-00.../dp/B000XTP0A8
    Jason
    Ontario, Canada
    WOW! I was going to buy a new deburring tool, but that looks like a much better investment.
    leland nc
    i have a 3/8 wire brush with a long shinny wire handle witch i bent on a 90 so i can just slide it in a clean the senser and ignitor if spark
    if i have to pull it then grin an bear it
    We install the 33" Luxaire, and I have found that my mini socket is the best way to handle the flame rod.
    Oct 2011
    I also use the mini socket set with a phillips head attached to get the screw out, thats the easy part of the ordeal. Its the getting the screw back in while trying to hold the rod in place thats the hard part. I am thinking of trying to make the rod somehow friction fit tighter so it does not just fall out while attempting the screw re instal.
    The 33 inch mids are not too bad , a little more room .
    But the high e models are a different story.
    I can not believe they could design a furnace this way. A way to common part failure is just miserable to clean or replace. Was a 2 min job with the previous model.
    Having to pull the ventor to get at the rod is just stupid.
    Then again having to pull and replace all these cracked plastic
    drain pans is as well .
    and the G71, engineers!!! get off your a$$ and try it in the real world you lazy !!
    I usually pull the rubber connector and gas line, then use a flexible shaft with 1/4" nut driver. when I put it back it it is only finger tight.
    Oct 2011
    A simple grommet for the rod to pass thru, with a set screw facing the front would be a simple and cheap design addition me thinks. But what do i know I am just a Tech.
    wisconsin
    On the g61 just remove the hole burner box it's super easy then you can see the inlet better and check burners
    Ontario, Canada
    When I was trained on the G61, they told me to remove the burner box cover and rubber exhaust boot to access the sensor, so I never really looked for an easier option. furnacedoc are you saying it's easier to remove the whole burner box? If that's the case, I can't wait for my next G61 maintenance call so I can try it.
    Quote Originally Posted by furnacedoc View Post
    I heard that from one of our guys, but it seems more work than removing the boot.
    don't you have to remove gas valve, wiring and what about the combustion air intake pipe?
    Ontario, Canada
    Definitely not easier to remove burner box on G61!
    I love my job, because it allows me to help people. I just dislike the part where the people I'm trying to help, want to help me help them.
