Results 1 to 11 of 11
    Jan 2006
    We have an old BDP Company Day and night closet furnace.
    not sure of the model number at this moment
    The blower has just started coming on continually for about a week now and wont shut off. the pilot light works and the heat works just fine, when the heat turns off the fan constantly runs and wont shut off unless we turn the furnace on off switch to off. Could someone suggest what the problem might be and where we would find parts for this furnace?
    Memphis
    Sounds like your fan relay is stuck on your circuit board. I bet its one of those boards that have the two glass relays on it. That board will have to be replaced, gonna have to call a pro.
    Life is like a jar of jalapenos. What you do today might burn your ass tomorrow.
    Apr 2003
    arizona
    Is the fan option on t-stat set to on or auto ? anything deeper than this I would recomend calling a technician out
    Jan 2006
    we dont have a on or auto switch on the thermostat
    Apr 2003
    arizona
    call a pro..........
    Jan 2006
    I am pretty handy i have done quite a bit of remodeling i think if someone could tell me what the problem could be I could buy a new board and install as long as the part came with wiring instructions, or is this kind of thing betterleft to the pros and if so what would be a good price range.
    Jan 2006
    you really should call a pro, if it is the board and you burn it up its your baby and will have probably have to buy another one, save yourself the time and money and call a pro
    i think my thermostat is bad
    Lancaster PA
    Call a pro.
    It will cost what ever is appropreiate for your area.
    Jan 2006
    I would most certainly call a pro i think evryone is right on with the board
    burlington county n.j.
    rules are no diy advise and no pricing, you really need to call a pro. bryant or carrier contractor may even have part on truck if you describe problem. very common fix.
    Unfortunately, we as members, can not help you with technical problems due to the site rules.
    It would be in your best interest to contact a competent HVAC Company in your area to diagnose and correct the issue. This way you will have a warranty and a unit to keep you and your loved ones warm and safe.
