Results 1 to 6 of 6
    Oct 2011
    Question Flex liner Weather King 80 Plus Upflow Gas furnaces
    I have a Weather King 80 Plus Upflow Gas furnaces Just found out that I need a chimney liner all I can fit in the chimney is a 4” flex liner the space is 4.25x19 that I have to shove it through and at the lower part of the chimney its 4” exactly for about 3 feet my question is on the paperwork for the unit is has vent 6 (152) may be 1” (25mm) with type b vent. Can I use the 4” flex liner for a happy medium. The unit has a power vent on it. There is a 3” vent pipe that comes off the unit and into the chimney. On the paperwork it has May require a 3” to 4” or 3” to 5” adapter I’m going to be using 4” double wall aluminum liner. I will like to order the liner but I dont want to get it if it will not work cant tack it back after its used Thanks for the help. sorry I also posted this in general
    Best to have an on site tech see what can be done.
    Oct 2011
    I did he is telling me 4" is good for it. Tuesday its going to get installed so I will see if it works. He told me i can go with 3" if I wanted.
    Get a CO detector! You'll need it.
    Aug 2011
    Lewes, DE
    why do you have to get a chimney liner??
    Aug 2011
    Lewes, DE
    CO monitor* stay away from that UL listed junk.
