Results 1 to 13 of 20
10-06-2011, 07:08 PM #1
- Sep 2011
- 14
charging 410a split on a cold day
Any ideas on how to properly charge a 3 ton 13 seer york straight air unit on a brisk day? The unit is equipped with a piston, yes a piston. They recommended charging by superheat but the ambientt o/a temp was too low to intersect the chart on the outdoor panel. I had to get it running so i drove the head up until i got about 16 deg. S.h. I wasnt real happy leaving it that way. Any suggestions?
10-06-2011, 07:23 PM #2
- Oct 2007
- Southern Indiana
- 94
weigh it in
10-06-2011, 07:26 PM #3
Ball park is about all you can do until you have a load. Sucks but you should recheck on a warmer day. But In the real world that's about all you can do imo.
10-06-2011, 07:28 PM #4
Weigh it on package and splits check how much condenser charge per ft.
10-06-2011, 07:29 PM #5
How long is the line set and what size ??
10-06-2011, 08:08 PM #6
- Sep 2011
- 14
15 ft lineset approx. not including i.d. coil.
10-06-2011, 08:10 PM #7
- Sep 2011
- 14
3/8 -3/4 3 ton. Came with 15 ft of charge. Just wasnt satisfied due to low ambient & low load.
10-06-2011, 08:20 PM #8
- Feb 2010
- Landis North Carolina
- 528
charging heatpump in heating
seeb my thread,charging heatpump in heat mode.
10-06-2011, 08:20 PM #9
- Feb 2008
- Ontario, Canada
- 40
I would do it right. You don't want to risk HO running an overcharged unit. Why piston?
10-06-2011, 08:49 PM #10
- Sep 2011
- 14
Thats what the engineer called for. I questioned the piston too but they didnt care. The condensor was feeding a fcu. It was in an industrial setting.
10-06-2011, 09:03 PM #11
York uses a piston. Only trouble with weighing in is you have to ASS-U-ME that the factory got the original charge right which I never believe. Get it close and check it again in warm weather. Got some kind of low ambient control on it? Crankcase heater? 3 ton is probably a recip.
10-06-2011, 09:07 PM #12
- Feb 2008
- Ontario, Canada
- 40
Oh right. I know what you mean. Engineers don't like to be questioned by us, who actually do the work and have a deep understanding of how things work. LOL
10-06-2011, 11:59 PM #13
- Sep 2011
- 14
Scroll compressor, low ambient, & crankcase r. all on it. I guess i will bug the foreman fitter to allow me to go back when its warmer (if there sre any warm days left) N.E.Pa. thanks forr everyone 's input.
