Results 1 to 10 of 10
Thread: York DXS Heater
10-06-2011, 05:01 PM #1
York DXS Heater
So any tricks to getting a compressor heater out a DXS?
I was almost temped to drill a 5/8" hole on the backside, so I could just hammer it out. But I went the long root and drilled the porcelain out. Then drilled the stainless sleeve out.
There's got to be an easier way?
10-06-2011, 08:05 PM #2
Professional Member*
- Dec 2008
- Dixiana, AL
- 2,487
Actually, no, there's not.
10-06-2011, 10:19 PM #3The weak aren't destroyed by the strong.
The weak are destroyed by the under-estimated.
I know a famous song that ends in 'my nose'. The artist is dead. Know who?
10-06-2011, 10:53 PM #4
- Dec 2008
- Dixiana, AL
- 2,487
10-07-2011, 04:51 AM #5
I concur get yourself a drill with the proper size bit and length and something that won't burn up while your doing it outside ones are better than the inside ones laying on your side in between the compressors when you install the new one put some never seize on that *****. (OMG)!
Arguing with your Boss is like wrestling with a pig in
mud.
After a while you realize that while you are getting
dirty, the pig is actually enjoying it.
It is not exactly cheating, I prefer to consider it
creative problem solving.
10-07-2011, 09:13 AM #6
- Aug 2009
- Prattville,Alabama
- 1,105
What the heck is it with York and oil heaters? I have 2 older YS chillers (YS DB DA S2-CJA). One has a failed oil seperator heater that is stuck in the well. And it's located on the side of the seperator facing the compressor, where access is extremely limited. What freakin' engineer decided that! Local York guys have tried repeatedly to remove it, with no sucess. So, what is the planned fix(as suggested by the factory)? Recover oil and refrigerant, remove the seperator, set it on the ground, replace heater and well, reinstall seperator, evacuate and charge. All that for what should be a simple repair! I've seen some questionable engineering in my time, but this one takes the cake. Needless to say, the new heater will get anti-seize on it. And the annual service will include remove, clean, and inspect heater. Then apply new anti-seize and reinstall heater. Rant over (for now). Didn't mean to hijack your thread ascj, but your problem looked to be resolved, and I thought you might appreciate somebody else sharing your frustration.
Last edited by Nuclrchiller; 10-07-2011 at 09:15 AM. Reason: clarify whose plan this is.
10-07-2011, 12:40 PM #7
And if you think this is bad wait till you have to work on first generation YCIV compressor they are all up under the front of the machine you will need a hamster to work in there with you ! ( They design it but they will never service it)
mud.
10-07-2011, 02:39 PM #8
10-07-2011, 05:06 PM #9
The problem was the 135 degree 5/8" bit I had, was getting wrecked by the porcelain. So I had to use a 1/2" masonry bit to drill out the center. Then go at the stainless.....which was a nightmare. Bit kept on catching. It's done, but it sucked. Just waiting for the overpriced heater to come in.
10-07-2011, 10:08 PM #10
I think if I ever have this problem, I will measure the circumference of the comp. right by the foot with heater, and order a band type heater to fit. It would have to be better than the heater in the foot of the comp. That's alot of pot metal soaking up and dissipating heat, before the heat gets to where it's actually needed.
