Results 14 to 26 of 31
    Delaware
    little bit of pressure.
    Always here
    Mar 2011
    Galveston Texas
    gas heater check just prior to blower and prior to the coil. Reason for that is a heater is designed to push x amount of air. The designers don't know what coil your putting on it so they do it for the heater itself. for an airhandler (coil and blower in same cabinet. ) check incoming and outgoing. Reason for this, is that the designers know what coil is in the cabinet and designed appropriately.
    Boise, ID
    Wow.....allot of questions being tossed out here.
    To the OP, if your return sp is greater than supply the return is undersized or you have dirty filter. Systems that I do I always have the return sp is less. No rule of thumb, but I want to keep return sp low because it's easier to push the air than draw the air.
    There is talk of pd across the coil, bear in mind the coil will have a pd for wet and dry conditions....always design for wet conditions and a dirty filter. The only real way to know if the coil is dirty is take a reading across the coil, I.E., before and after. Hopefully you will have mfr literature to tell you what the pd should be at the cfm your system is providing, and coil status (wet or dry)
    The question was asked about literature to read...I will think about that and see if I an find something, but SMACNA manuals or ASHRAE fundamentals comes to mind. If you have a specific question, post and I will try and answer.
    I disagree that dirty filters etc. result in higher operating costs the system is working more. It is actually working less. Take a blower and run it wild with no restrictions....amps go up. Stick board in front of the outlet and restrict flow and amps go down...it's moving less air and doing less work. Your losing efficiency, which wastes energy and is a loss of efficiency causing the system to run longer.
    What is important is tesp. If the coil is cut in, add that to tesp when looking at blower curves. If the coil is integral to the air handler, disregard unless your trying to find out if its dirty.
    Politicians need to be changed like diapers, and for the same reason.
    Mark Twain
    Tulsa, OK
    Attachment 216462Before the coil period, and as close to a good center of R/Air at heater cabinet with filters installed. Your after the fan wheel input and output with a ****Wet Evap Coil****. This is full load evaluation at the home installed instead of just a factory chart. Remember Factory charts are bench test best guides to help the tech, it's up to you to make a real on site decision of many factors like supply vents closed and furniture to low to allow stratification of airflow, returnable airflow to the return grills and many many more more only real world experience techs finally learn home to home new or used!
    Jun 2011
    Hm, sounds like there are alot of factors for SP and many routes to take...
    Maybe just a general checklist of things to check for Low readings, and high readings.
    Low SP causes & High SP causes.
    I do understand now the purpose of checking SP without the coil in the way because the Manufacture designed the Furnace W/O the coil in place. What do people usually do in uplflow/downflow/horizontal applications for checking the supply side? Remove the high temp limit or drill another hole?
    Central Kentucky
    There is a member here by the name of rundawg who made a static pressure manual and posted it here some time ago.
    It was a great piece on the topic.
    Do a search on his name and I'm sure you'll find it.
    If anyone is interested send me an e-mail or pm me and I'll send you some of the static pressure training material we use in our classes too.
    Have you set up a Google alert for Carbon Monoxide yet?
    Click here to find out how.
    "hvac r us 2" made a video that will help many.
    Jun 2011
    Static
    I was told that esp should be taken distance of 2.5 times the diameter of the blower wheel from the center of the blower shaft.
    Jun 2010
    Philadelphia PA
    As a general rule, you're right
    Quote Originally Posted by JBM1000 View Post
    But if you look closely at the manufactures info you'll find that YORK for instance , gives ESP values WITHOUT filters And very intelligently then gives some instruction as to why you may for instance need 2 return elbows and filters for say a 5T unit
    Jun 2010
    Philadelphia PA
    Gib's Son I agree with both ideas
    Your's
    I think the underlined sentence agrees with " result in higher operating costs the system is working more." that you said you disagree with
    But I like your point about amp draw. Counter intuitive isn't it!
    Feb 2011
    New Jersey
    When a furnace tune-up is being performed by reputable person/agency do they undertake such static pressure tests in supply and return and thus adjust (if possible) accordingly? Or, this is something completely out of the purview of maintenance?
    Jul 2005
    Quote Originally Posted by genduct View Post
    With a constant cfm ECM blower the amps will go up as the filter becomes restrictive.
    I assume that Gib's Son was responding to Desuperheater's statement. But here's what he actually said "Less ESP at equal CFM means the blower is working less, might last longer and will use less energy." Which is correct. HTH.
    It should be
    Quote Originally Posted by wisepole View Post
    determined at installation and bench marked. It should be checked on each maintenance call to help determine if the system is functioning propperly.
    Most companies will not check it because they do not know what it should be, or where to take the measurements.
    Reputable person/agency is a relative term.
