    Oct 2011
    Can Outdoor Temperature Sensor be used Indoors?
    More specifically, can the TSTATXXSEN01-B Outdoor Air Temperature Sensor be installed indoors?
    I realize my display module will still read "outside temp" - but I'll know that it is actually displaying the temperature at the indoor location of the sensor.
    Feb 2011
    North East Ohio
    My only question is why??
    Oct 2011
    i would like to be able to read the temperature of an accessory building i have on my property (a workshop that is across the yard).
    I have no good reason, other than just wanting to quickly and easily be able to see the temp of my workshop
    Feb 2011
    North East Ohio
    You can go to Home Depot or anywhere like that to get an "out door weather center" which has 2 units that communicate wirelessly. That should accomplish your goal
    Oct 2011
    a great suggestion and probably easier and cheaper than my solution - although not quite as elegant...
    thanks
Tags for this Thread
