Results 1 to 13 of 54
10-05-2011, 09:18 AM #1
- Jul 2005
- FLORIDA
- 1,162
anybody seen this yet and is it snake oil
ENDOCUBE
http://endocubeinfo.com/
might as well put tsat bulb in a tube of jelly for 3 hundred bucksonce you think you've seen it all
(THINK AGAIN)
I would rather work for free than be look upon as a thief!!!!!
10-05-2011, 09:33 AM #2
Seems to me the Temp Diff from kick on to kick off would increase too much making huge swings... wouldnt that be just as bad ?
10-05-2011, 09:48 AM #3
- Jul 2005
- FLORIDA
- 1,162
that and they are trying to sell it to a flower shop and with long run times they will dry out the product
(THINK AGAIN)
10-05-2011, 09:52 AM #4
Basic Truth in Life:
If it sounds too good to be true, it usually is.
10-05-2011, 10:30 AM #5
- Apr 2007
- Scottsdale,AZ
- 58
Same thing as the bottles of glycerin in lab r/i's
10-05-2011, 11:46 AM #6
I hadn't heard of that brand, but this one has been around for a few years.
I'd have to vote for "Snake Oil"...considering the vast majority of self-contained reach-ins use a constant cut-in, coil sensing temperature control, it goes without saying that these little gems wouldn't work very well.
10-05-2011, 09:21 PM #7
- Jun 2011
- 28
Interesting idea,reminds me of a wine cooler control which was a probe in a bottle of fluid which sensed fluid temp. and cycled unit through a logic board which also inputted room temp. and humidity.Very limited/specific application but quite effective.
10-05-2011, 09:30 PM #8
I read until I hit the phrase "thermal inertia"
Then something shorted out in my brain and I decided that brain cells would commit mass suicide if I read any further.
10-10-2011, 10:37 PM #9
Why not just stick the sensing bulb in a carrot. When the carrot gets above 40 the unit kicks on. When the carrot is at 33 it cuts out
10-11-2011, 02:36 AM #10
- Feb 2003
- 1,165
10-11-2011, 06:36 AM #11
Why not just stick the probe in THE BUTT OF ENDOCUBE's CEO to get a true temperature reading.
10-11-2011, 07:51 AM #12
- Sep 2008
- Cedar Rapids, IA
- 473
Seen similar sensors used to monitor/mimic product temp. They were used for alarms only, not to control the equipment. Same with the glycerol filled bottles in lab units. Usually for the recording equipment. One problem with using them to control food equipment is the health department. If they see air temps above 41 degrees they will tell you to toss the food.
02-28-2012, 09:20 PM #13
Just had this product, introduced onto another forum for frosties!
So the engineers out there ask for a bit of engineering proof of the principles on what they claim.
best reply from those flogging the ecocube, is "Trust me, it just works"
SNAKE OIL with some added live Dodo droppings.
