Results 1 to 9 of 9
    Aug 2010
    honolulu, hawaii
    mitsubishi city multi fcu help!
    Pefy p36 nmhu e
    I found the Lev coil faulty and needs to be replaced.
    Does anyone know if it can be replaced by accessing the side triangular panel? Or only through the bottom access panel?
    Aug 2010
    honolulu, hawaii
    Someone had to of worked on this unit. Please help
    Colorado
    Just curious
    How did you find it faulty if you couldnt access it?
    Colorado
    on lg mini splits it can be taken off and replaced by digging and digging until you get to it. Sorry, all those mini splits are so compact its brain damage to get to anything. Mitsubishi is alittle better in my opinion than most the others.
    I know its not much help. Sorry! Just take the outer casing off one panel at a time an don't loose the screws!
    Colorado
    You can usually find the service manual online and download it for those units just for FYI. Goodluck
    Hawaii
    1.Removing the LEV.
    (1) Remove the control box cover with procedure 8-1.
    (2) Remove the fixing screws (four) of the heat exchanger cover
    (A), and remove the cover (A).(Fig. 1)
    (3) Remove the LEV driving motor with a double spanner.(Fig. 2)
    Hope this helps.
    Aug 2010
    honolulu, hawaii
    Thx all, I used the manual, there is a set of Ohm readings that must be read to confirm proper operations
    Feb 2007
    Southern California, LA Metro
    Quote Originally Posted by Coredog View Post
    For the record, a PEFY-P36 is a City Multi 3ton ducted air handler. Not a mini split, which usually is synonymous with ductless one on one systems.
    Larger Duct, Larger Duct, More Air, More Air
    READ THE MANUAL
    What if I train them and they leave?
    What if you Don't train them and they Stay!
    DSG member
    Oct 2011
    Canada
    the side panal is where you access the LEV motor not a hard job
Plumbing Talks | Contractor Magazine
Forums | Electrical Construction & Maintenance (EC&M) Magazine
