Thread: YCAS Oil Line
10-04-2011, 06:16 PM #1
YCAS Oil Line
What is the oil line made of? I have a oil isolation valve leaking. Threw a magnet on it, so I thought it was aluminum. Cut the valve out and seems like stainless steel. Is it stainless?
10-04-2011, 06:54 PM #2
Professional Member*
- Jan 2009
- Jersey
- 119
stainless
10-04-2011, 06:59 PM #3
- Aug 2000
- Austell, Ga.
- 1,248
Yes it is stainless steel.
Two types of stainless steel exists and they are Martensitic ans Austenitic.
Austenitic is non-magnetic whilst Martensitic is.
The higher priced Austenitic is virtually non heat treatable and is far superior to not cracking due to vibration as long as its operating temperature is kept below 500-800°f.
Austenitic makes a wousy' knife blade but sure is pretty..Ain't "None" of us as smart as "All" of us..
10-04-2011, 07:01 PM #4
10-04-2011, 07:41 PM #5
- Dec 2008
- Dixiana, AL
- 2,487
Works every time, but I'm wondering why you'd sweat copper to both sides? Why not use a sweat ball valve and 45% one end to the existing line, then put the stub on the other end and cut out one coupling - or is my thinking screwed up about what you meant? You can also use Swagelok fittings and new stainless line (at least .045" wall) if that works better.
10-05-2011, 05:23 PM #6
- Jan 2009
- Jersey
- 119
I've put them in with copper stubs and also with the Swagelok, both work and haven't have them fail.
