Page 3 of 3 FirstFirst 123
Results 27 to 33 of 33
Thread: My day at work
  1. #27
    Nov 2003
    Boston
    Originally posted by otto
    The shaft is 2 15/16" and the blower wheel is a backward incline wheel with airfoil blades and about 82" diameter! I think it's a 50HP motor.
    otto,
    I've got a 10 year old building with 12 fans of a similar size. So far the shafts and bearings are OK but I'm dreading the day when I have to pull a shaft that size.
    How do you handle that? Cut the shaft near the hub and then sledge hammer away?
    Edited by powerhead on more than one occasion
  2. #28
    Apr 2005
    where the beer flows like wine
    [QUOTE]Originally posted by Carnak
    [B]Lol, you like your men clean shaven
    yes I do , would you like to go out on a date? you dont have a mustache do you?
  3. #29
    Apr 2002
    No I am not clean shaven, but as long as you do not have eyes in the back of your head I don't think you would mind
    [Edited by Carnak on 01-05-2006 at 10:08 AM]
    http://www.ductstrap.com/
  4. #30
    Apr 2005
    [B]No I am not clean shaven, but as long as you do not have eyes in the back of your head I don't think you would mind
    I like to kiss and cuddle and your hairy face would freak me out, you are all about sex, thats all you care about, how about my feelings! you chauvinistic pig! ;(
  5. #31
    Dec 2001
    Chicago, N/W burbs
    Powerhead,
    This bearing, fortunately, was on the pulley side. We're having a bracket extended uot so we can use a good part of the shaft towards the blower wheel. As for the rear, there's also room to extend the mounting surface. Haven't had to replace a 3" shaft yet and I don't look forward to it whenever it comes along.
    R2B4BTU
  6. #32
    Link belt bearing ?
  7. #33
    Feb 2005
    Barrie, Ontario
    How tough was the old bearing on there? I can slightly see the shaft.
    I did a 1 3/16 last week and it moved about an 1/8th inch and jammed on me... had a 20 ton puller and it wouldn't budge it...had to burn it off. Did okay though.
    Sometimes I can't believe how nasty they can be.
    Used to do 4" regularly at the General Tire here in Barrie before they closed up- 2 piece pillow blocks with double rollers. They were easy compared to some...also 20' in the air as well.
    Is this a Fabreze moment? C.Y.D. I'm voting white elephant. 2¢.
    My competition are my best salespeople!
