Results 1 to 10 of 10
Thread: Copper Drainline
10-03-2011, 09:48 PM #1
- Jul 2006
- 528
Copper Drainline
What is the purpose for a drainline for a regular HP to be made of copper vice PVC? I work for the gubernment, and many thing's do not make sence, but this one has me stumped. I ran the line as per drawings, and insulated it inside the warehouse space. I joked about it. The Public Works Engineer's told me if a drain line crosses a human occupied space, it must not be PVC. Well, words to that effect anyway. I say B.S. If it's fire they are worried about, melted PVC from a HVAC system is the least of their worries.
We have a computor room with 3 Liebert AC systems that have built in humidification. I can understand the copper drain lines for that, in case the humidification circuit fails and steam travels down the drain, but Resi grade Trane HP's?
10-03-2011, 10:21 PM #2
i did a dr's house one time and he wanted all drains in copper, and paid extra for it, he stated that algea and other bacteria cant grow on/in copper, have no proof of it other than what he said, but as i think about it, ive never been back to that job for a clogged drain line, (job is 8+ yrs old) something to think about
The 2008 NATE TOP TECH!!!!!
10-04-2011, 09:15 AM #3
- Sep 2011
- Vancouver, WA
- 180
The reason thats been given to me is that in a fire, pvc when burned, gives off a lethal gas. There has been fires where this product has been installed and the people inside were killed where normal smoke would have allowed them to escape. Most of the commercial building code that I have had to deal with gives this reason.
t
10-04-2011, 09:35 AM #4
Professional Member*
- Oct 2011
- NJ
- 90
When PVC melts it forms chlorine gas, which as previously stated can be deadly. It was even used as a chemical weapon by Germany in WWI.
If exposed to it, it mixes with water in body fluids and can form hydrochloric acid in the person's lungs.
You aren't supposed to run PVC exposed in air plenums or occupied spaces, unless it's plenum rated.
10-04-2011, 11:10 AM #5
- Jan 2008
- Dallas ,Texas
- 3,509
UA 100
It takes three people to do anything around here. Two do the work, one explains to the crowd of people who showed up when they seen smoke and flames.
10-04-2011, 09:13 PM #6
What about the PVC drains and p-traps that are under virtually every bathroom and kitchen sink in the country? And I haven't seen a copper drain line on an upflow horizontal installed in a closet in the home's interior in a very, very long time. Go look in a large commercial kitchen sometime and note all the PVC used there. You should never use standard PVC for a T&P relief line on a water heater or boiler though.
I agree that it gives off toxic gases when burned but there is way more PVC used in the products in your home than an AC drain line.The picture in my avatar is of the Houston Ship Channel and was taken from my backyard. I like to sit outside and slap mosquitos while watching countless supertankers, barges and cargo ships of every shape and size carry all sorts of deadly toxins to and fro. It's really beautiful at times.....just don't eat the three eyed fish....
LMAOSHMSFOAIDMT
10-04-2011, 09:27 PM #7
10-04-2011, 09:29 PM #8
- Sep 2006
- Ohio
- 344
I have seen Medical Buildings that used Water Source Heat Pumps in every suite. They had PVC water lines and drain lines on every one of them.
10-06-2011, 12:52 PM #9
- Jan 2007
- USA
- 13
I work for a company that makes WSHP units. We use copper to make our condensate drains because it is commonly available. I doubt anybody here ever considered copper does kill fungus. It is commonly used as a fungicide for trees and shrubs.
10-06-2011, 05:31 PM #10
One thing is that copper lasts longer. Even if for no other reason. I mean, how often have you seen pvc drain lines that are old and brittle and cracked? I have seen a ton of it. It is more expensive, but if I were going to install my own unit, it would be copper and not PVC just so I know it won't break as easily. FWIW I have always seen only copper drain lines in walk in fridges and freezers. It is probably code there. In freezers, you have to attach heat tape to the condensate drain so the line doesn't freeze up so only metal would work.
