Results 1 to 13 of 35
    Aug 2011
    reverseing valve need help installing
    Can anyone of you guys please help me out i installed a reverseing valve on a trane split heat pump it was very difficult to weld in the vavle was very close to the outdoor coil just want to know if anyone has a easier technique and would be willing to share the knowledge i would be very thankful
    Rochester, NY, USA
    I usually hang a wet cloth on the coil to protect it from the flame.
    My suggestion to installing a RV, use Stay-Brite 5% silver solder. It melts at 436°F, always try and point the flame away from the valve body, wrap the body with wet cloth, do one tube at a time then cool it off, if you try and do all of them you'll cook the valve.
    we all have our own opinions on how to do things, but that's what I do and it work for me
    Good luck
    Measure Twice
    CUT ONCE
    Crap, throw that away and get a beer
    May 2009
    There is no easy way to install a reversing valve. They all will make you want a shot of crown!
    Aug 2010
    sometimes it's easier to take the coil out, replace the valv, then put the coil back in.
    Oct 2009
    aiken s.c.
    Hmm
    I have found that sometimes it is easier to cut the old valve out and braze stubs in outside of the unit also. However this does bring up an interesting question; What do you guys use to braze reversing valves? I have always used Sil-Fos but I can"t help but wonder if there"s not something better?
    Jan 2011
    greenville , sc
    i use "gutter glue" ..NOT...
    i use either of the methods mentioned above just depends on the situation .
    i have to say though high heat and quick brazing usually gets me through.
    very hot very fast.... not to much heat transfer.
    catch a man a fish , feed him for a day.
    teach a man to fish , ruin a good business opportunity.
    Rochester, NY, USA
    Quote Originally Posted by aikenite View Post
    see post #2, Stray-Brite melts at 430°F and has the same tensile strength as braze, the issue is the price. One pound costs a small fortune and you must use there flux.
    Measure Twice
    CUT ONCE
    Sep 2011
    Don't use solder on a 410 unit, the manufacturers say that the high side pressure is too high. Ive never tried it, but Ill take their word for it.
    Rochester, NY, USA
    Quote Originally Posted by SwampTromper View Post
    time to put a call into Stay-Brite and see what they say. *supposedly* it has the same tensile strength as Sil-phos???
    Measure Twice
    CUT ONCE
    las vegas
    i put 2 valves in earlier this year with sta brite on 410a systems
    & so far they are holding up well.
    Jun 2011
    Houston area
    Never do it yourself
    Reversing valves are for helpers. Make him do it and then cuss him out real good when it leaks. Your helper will feel like crap and develop self esteem issues but you'll feel superior.
    Of course I'm just kidding. RV's can be (and usually are) a royal PITA. I have used 15% with success on both R22 and R410 systems but the liquidus temp is 1465F so you have to get it hot. Use an oxy/acetylene rig and hit it quick and clean. You should not have to have your torch on the tube for more than 15 seconds or so. Wrap the valve with strips of dripping wet cloth and do the tubes one at a time.
    jmac00 are you sure you're not referring to Stay-Silv 5% as opposed to Stay-Brite 8% ??? The Harris website doesn't list a Stay-Brite 5% but does list 8% with 430F liquidus
    The picture in my avatar is of the Houston Ship Channel and was taken from my backyard. I like to sit outside and slap mosquitos while watching countless supertankers, barges and cargo ships of every shape and size carry all sorts of deadly toxins to and fro. It's really beautiful at times.....just don't eat the three eyed fish....
    LMAOSHMSFOAIDMT
    Rochester, NY, USA
    Quote Originally Posted by Cooked View Post
    my apologizes, you maybe right. I thought the guy said 5%, but it maybe 8%. All the roll says is "Stay-Brite....Silver-Bearing solder" RoHS compliant.
    I got this stuff to solder in a Modulating mixing valve. It did cost me $60freaking dollars for a one pound roll and $20 bucks for the flux
    I really like the stuff, low melting point, excellent flow, excellent tensile strength
    Measure Twice
    CUT ONCE
    Jun 2007
    Round Rock
    Charge them so much for the RV change that they buy a new unit.
    I like DIY'ers. They pay better to fix.
