Results 14 to 18 of 18
    Sep 2003
    Ocean County, N.J.
    Thanks RoBo and hvac-tech-lane. I wasn't going to post, but now I'm glad I did. Always eager to learn. Thanks.
    leland nc
    i normaly go high on the pleanum in line or as close to the main trunk take off
    even still why are you getting a 40 degree differance in only a few feet
    robo has a point 5 degrees from point a to regs
    Apr 2003
    Originally posted by deejoe
    To actually arrive at a true "temp rise" of a forced air furnace where is the supply temp taken?
    Nov 2000
    Eastern PA
    For the supply, I agree with that diagram. For the return, I prefer being closer to the blower, especially if there is a filter near the blower where air leakage into that area could change the average temperature hitting the heat exchanger.
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    Nov 2000
    Eastern PA
    Sometimes, for simply unknown reasons, we will hit hot of cool spots in the plenum or ducting. What it would take to pinpoint the reason for the hot/cold spot is just not worth the time or effort in the field.
