Results 1 to 11 of 11
    May 2009
    Pipe connection question - gate valve steel pipe
    is it possible to attach a gate valve to a steel pipe (3 inch) without welding?
    being done on a hot water heating pipe
    trying to avoid use of a torch near wood wall.
    thanks
    in a house, Appomattox, Va.
    thread it and use a threaded valve. or flange and flange valve.
    or go back to nearest fitting on either side and repipe section in middle with pipe, union and valve
    Col 3:23
    May 2009
    can a gate valve be attached to a coupler that has been afixed to a steel pipe with a victoulic groove?
    yes. they make a fitting that will attach to raw pipe, then get a short nipple raw to groove and a vic flange, done.
    Feb 2011
    Sacramento, CA
    Quote Originally Posted by zeppy View Post
    thanks
    Why a gate ? Why not a full port ball valve? More expensive, but a much better valve in my opinion.
    I have done so much with so little for so long, that now I can do almost anything with nothing at all.
    Anytown USA
    Quote Originally Posted by flange View Post
    they make a fitting that will attach to raw pipe .
    That fitting comes in handy, I just used 2 of them on 3" a couple months ago. Made the job a little easier.
    remembered the name, roust a bout coupling by victualic
    Dec 2010
    georgia
    Yes this is a great product.
    Oct 2011
    Mesa Az
    Agreed , have used many. You dont want to weld with a torch anyway.
    May 2009
    the valve is being used to valve off an extension of pipe that will never be used again.
    pipe being sealed off is a vertical extension that needs to be empty indefinately.
    so the seal on the pipe is very important. quality of seal from a gate valve is better than a ball valve
    ideally, a cap should be used on the coupling to simplify work and ensure a much better seal.
    a ball valve in the closed position may be inadvertently adjusted over time and then water would leak into a chamber that needs to be empty to avoid potential pipe freeze (a hose bib above valve is not being installed so it will be difficult to assess if any water has leaked into the empty pipe - poor design approach)
    Aug 2008
    They make die nut's that you can use a socket and rachett on so you can thread something in tight place's. Expansion plug's work good also, sometimes you have to use a reamer to get a good contact area.
