Results 1 to 8 of 8
    Urbandale IA. USA
    Refresh my memory
    What factors affect moisture (sweating) inside the flue of an 80% furnace installed in a basement?
    Those who dance, appear insane to those who do not hear the music.
    Those who believe, appear ignorant to those who do not know God.
    Oct 2009
    Rhode Island
    below 130degree flue gasses that wont happen at 80% tho check the flue gas
    s chester county,pa
    short run times = the answer
    Jun 2009
    Nevada
    Not enough heat. Did you downsize the furnace? I've seen moisture run down the flue and fry a circuit board.
    Sep 2009
    Flue gas temp, flue type, flue size, draft.
    Sep 2011
    Souther Cal
    Are you running the flue into a chimney or other concrete or brick flue?
    Urbandale IA. USA
    5" flue, double wall from basement through the middle of the house all the way to the roof (2 story).
    Furnace has a 4" going into the 5" along with a 3" from the gas water heater.
    I have NOT measured the flue temp.
    Sep 2011
    Souther Cal
    I would measure the flue temp, the furnace is induced draft correct, since the main flue is 5" I am not sure if the standing pilot in the water heater will produce enought heat to keep it from condensating. In a cold climate area I had to insulate the doulble wall flue to stop this problem . Mainly in the basement.
