Results 1 to 9 of 9
    Dec 2008
    Buffalo NY
    Confused Water in 80% furnace heatexchanger
    I just got back from a no heat call. Furnace is a 1993 Comfortmaker 80%, 150000 btu's. The basement is stone and very moist (mushrooms growing on the dirt floor).
    Furnace flue was very rusty, took the covers off and found a lot of moisture in the vestibule. Took the cover off the burners and found the tubes of the heat-exchanger filled with an 1 1/2" water. I figure it was caused by warm air circulating through the furnace during the summer and condensing in the heat exchanger. Also there is no A/C. I condemned the furnace and recommended replacement. This is the first time I have seen this. Does my theory of how it happened sound right? Also they never ran the blower during the summer.
    To the man who always did it right. I love you dad and I will miss you to much for words.
    Stay Thirsty My Friends
    Support the Skilled Trades Don't DIY
    Pa
    We ha plant that has a sludge tower with a steel catwalk that has sludge below it. This building requires heat and the combination of moisture and the constant 45 degree air filledthe heat exchanger with water.
    Nov 2010
    Cincinnati, OH
    I would guess the basement flooded. Is this rental property? Maybe the tenants didn't want to tell the land lord they flooded the basement some how. Was there any water in the blower?
    Jun 2009
    Nevada
    Maybe you need to adjust the float ...
    Syracuse, NY
    I ran across this on a rheem furnace 80%
    I ran acrossed this with a rheem furnace installed in a apartment building and found that the roof vent cover was off and caused the furnace to fill up part way with water. the furnace fired up and blew flames out the front of the furnace and fried all the controlls.
    Life is to short to sweat the little thing in life!
    Sep 2011
    Detroit MI.
    ggtg
    Coworker found this in Sis's Trane 80. We're going to look at it further tonight. It's in a cold, damp dungeon of a room in the lower level. Not sure what the answer is on in installation like this other than try to lower the RH in the room with a BIG dehumidifier.
    Dec 2008
    Buffalo NY
    Nope not a rental. This is my cousins new house. He was in it last winter and did not have a problem. This was my first time at his new house though.
    Quote Originally Posted by oldblue View Post
    I don't know
    Dirt floor?
    Maybe some kind of vapor/moisture barrier can be put over it.
