Page 1 of 4 1234 LastLast
Results 1 to 13 of 40
    Jan 2011
    Bradford On. Canada
    Confused start & run capacitors
    Does it matter if you change a compactior (start) with a run compactior?
    I have gone into to the supplier to find only run compactiors, and I would like to know does it matter.
    Thank You
    Jun 2010
    North Fl
    need more details... What are you trying to do....
    HOPE IS WHAT WE CRAVE
    Southeastern Pa
    Yes, it does matter. They are not the same.
    We usually dicuss technical topics in the pro residential forum.
    Pros should post their technical questions there, or in pro commercial, as is appropriate.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Start caps and run caps might seem like they are similar, but they are very different. If you swap them around you might end up damaging a motor.
    Apr 2001
    Is 'compacitor' what you do to repair a swelled capacitor? Do you use a capacitor compactor?
    Jason
    In a machine room
    Quote Originally Posted by bja105 View Post
    I even googled it and couldn't find out what a compacitor is!
    burlington county n.j.
    if it didn't matter they wouldn't make both kinds.
    Sep 2011
    Has anyone noticed a pattern in the types of capacitors that are failing prematurely? I changed a 60 MFD @370 run capacitor on a compressor 4 ton. It was drawing 21.7 amps. With new capacitor the amp draw dropped to 14.1. In the last 10 years I have changed 5 times as many capacitors as I did in the 90's.
    Sep 2011
    It's just like everything else, made cheaper to keep the share holders wallets fat.
    Southeastern Pa
    That's funny. Just the idea of a shareholder with a "fat wallet."
    I think you should be on Leno.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Sep 2011
    wildwood missouri
    well so much for a kickstart t05 airexcellencestl.com
    Sep 2011
    Never seen leno, just facing the facts. Even the almighty trane has been outsourced to China and skimped to the point that its like the rest of the garbage. I'll leave the politics to leno... Just want a good product that will last and is worth the cost and capacitors doesn't fall in that slim category.
    AZ
    That's because the corect spelling is compacitior
