Results 1 to 13 of 40
    Jan 2011
    Bradford On. Canada
    Confused start & run capacitors
    Does it matter if you change a compactior (start) with a run compactior?
    I have gone into to the supplier to find only run compactiors, and I would like to know does it matter.
    Thank You
    Jun 2010
    North Fl
    need more details... What are you trying to do....
    HOPE IS WHAT WE CRAVE
    Southeastern Pa
    Yes, it does matter. They are not the same.
    We usually dicuss technical topics in the pro residential forum.
    Pros should post their technical questions there, or in pro commercial, as is appropriate.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Start caps and run caps might seem like they are similar, but they are very different. If you swap them around you might end up damaging a motor.
    Apr 2001
    Is 'compacitor' what you do to repair a swelled capacitor? Do you use a capacitor compactor?
    Jason
    In a machine room
    Quote Originally Posted by bja105 View Post
    I even googled it and couldn't find out what a compacitor is!
    burlington county n.j.
    if it didn't matter they wouldn't make both kinds.
    Aug 2010
    Little town in Texas
    oh yeah..
    Quote Originally Posted by t527ed View Post
    Yesterday, 07:35 PM
    t527ed
    Professional Member*
    make both kinds.
    ^^^....what he said...^^^
    Now that's funny...can't get more "matter of fact"..than that....damn...I might put that under my quotes...
    "If you can’t describe what you are doing as a process, you don’t know what you are doing." ~ W. Edwards Deming
    All those who wander..are not lost.
    Do NOT..mistake my kindness for weakness.
    The early bird may get the worm..but the second mouse gets the cheese.
    AZ
    That's because the corect spelling is compacitior
    Sep 2011
    Oklahoma
    Understand the type/variety of oil has changed....anybody got any info on this?
    Jul 2011
    Central PA
    Last week I replaced an evaporator fan motor in an ancient looking reach in freezer. It was an old GE motor, made in the USA. The replacement I got from Meiers' was also a GE only it was made in China. It failed after less than a week. May have been a coincidence but I'm more inclined to think the 12 year olds making $2/hr and working 15 hour days are slacking.
    Sep 2011
    Has anyone noticed a pattern in the types of capacitors that are failing prematurely? I changed a 60 MFD @370 run capacitor on a compressor 4 ton. It was drawing 21.7 amps. With new capacitor the amp draw dropped to 14.1. In the last 10 years I have changed 5 times as many capacitors as I did in the 90's.
    Sep 2011
    It's just like everything else, made cheaper to keep the share holders wallets fat.
