Results 1 to 9 of 9
    Dec 2003
    Central Connecticut
    Hello fellow Hvac junkies. Does anyone out there know where I can get the book "The Color Of Water" from PB pub. ?? I am trying to locate for some apprentices. Thanks
    Huntsville,AL
    AMAZON.com ~$11
    Apr 2002
    Omaha, NE
    Are you talking about the book titled: The Color of Water: A Black Man's Tribute to his White Mother ? I don't see why you would want it for apprentices. Is there an HVAC related book by the same title? Anyway, if the above book then it's available used even cheaper:
    http://dogbert.abebooks.com/
    and search by title in quotes
    [Edited by snewman24 on 01-01-2006 at 08:04 PM]
    Apr 2004
    I know what you're talking about
    But I lost my copies. It was a course Peerless boilers gave called "The Color Of Water". I Googled it like you probably did and all I came up with was that J McBride book. You should get in touch with Dan (the man) Holohan about a basic hydronics class. Or that other guy Seigenfalder? something?
    ...SHEEESH!!!
    Apr 2004
    Farfignewton???
    ...SHEEESH!!!
    Nov 2005
    The Color Of Water
    You might try here. This is an order form from Peerless.
    http://www.peerlessboilers.com/home/...HMaterials.pdf
    Regards.......
    Dec 2003
    Central Connecticut
    The book is on piping and designing hydronic systems. (unfortunatly has the same title as an unrelated book) I have checked all book stores with no luck.
    Dec 2003
    Central Connecticut
    Thanks bodhisatva....I think that you have the same book in mind.
    May 2002
    MEDIA PA
    snewman24 great book out let found book i've been looking for years thanks again
