Manual J tells you the heat loss/gain for an area, and this info can be used to size any heating/cooling system.
Can Manual J be used to size up a radiant floor system?
Not so...the potential for downward loss with a radiant floor heating system is great and must be properly analyzed.Originally posted by smokin68
A program design for radiant floor heat is the only program that has this ability...no others will do.
Thermal properties of the composite floor and floor heat loss are addressed adequately in a Manual J load analysis if performed by competent, experienced individuals.Originally posted by simpleman
[B]Not so...the potential for downward loss with a radiant floor heating system is great and must be properly analyzed. [B]Originally posted by smokin68
Designer Dan __ It's Not Rocket Science, But It is SCIENCE with Some Art. _ _ KEEP IT SIMPLE & SINCERE ___ __ www.mysimplifiedhvac.com ___ __ Define the Building Envelope & Perform a Detailed Load Calc: It's ALL About Windows & Make-up Air Requirements. Know Your Equipment Capabilities
