Results 40 to 52 of 57
11-12-2011, 02:54 PM #40
Professional Member*
- Oct 2003
- las vegas
- 1,505
had a big leaker last year & couldnt locate it with the insulated lines.
i borrowed a thermographic camera from a plumber buddy & was lucky
enough to find a cracked 90 in a liq. line within an hour.
11-12-2011, 03:39 PM #41
You said this was a Low Temp rack.... how many systems are Gas Defrost?
The views and opinions posted here are my own. They do not reflect the corporate policies of my employer and will most likely get me fired at some point.
11-12-2011, 05:24 PM #42
If you are evacuating a system that held refrigerant, I will GUARANTEE you that your detector will alert on the exhaust. Even at 0 PSIG, what, exactly, do you think is contained within the piping?? Fruit juice?
Hmmmm.
I've got on that I might need to look into this on one that I'm fighting right now.
11-12-2011, 06:42 PM #43
11-12-2011, 09:02 PM #44
[QUOTE=jpsmith1cm;11703452]If you are evacuating a system that held refrigerant, I will GUARANTEE you that your detector will alert on the exhaust. Even at 0 PSIG, what, exactly, do you think is contained within the piping?? Fruit juice?
I will GUARANTEE you, if you read the reply correctly, you could have saved yourself from sounding obnoxious.
This is an open forum....please refrain from child like behavior...and keep your fruit juice to yourself.
11-12-2011, 09:49 PM #45
As you said, this is an open forum.
I try to pop foolish ideas like that when I see them. This is to prevent someone who isn't knowledgable from coming along and accepting them as being accurate.
I apologize for offending you.
11-12-2011, 10:32 PM #46
- Oct 2003
- las vegas
- 1,505
11-12-2011, 10:41 PM #47
I regularly leak check Walmart stores and have had many hard to find leaks. Even so, the toughest still only took 3 days repairs included. I use an Inficon Dtek Select detector. It has no problem finding even the smallest leaks with 404a. The worst was under a set of frozen bunkers. Had to separate and move them to get it fixed. Good luck.
Never kick a lying dog.
11-13-2011, 01:17 AM #48
11-13-2011, 11:17 AM #49The views and opinions posted here are my own. They do not reflect the corporate policies of my employer and will most likely get me fired at some point.
11-15-2011, 08:37 PM #50
Sooooo..., you still workin on it? Cant just leave us hangin, where in circuit 2 was it?
11-15-2011, 09:24 PM #51
- Sep 2011
- Tampa, FL
- 45
Found 6 leaks with my new leak detector. 2 punctured evap coils and 6 suction line leaks. Coils have been replaced and all suction line leaks repaired. Thank god.
11-17-2011, 01:08 AM #52
Don't want to be a pest but could you tell me which detector you have now.
