Page 3 of 5 FirstFirst 12345 LastLast
Results 27 to 39 of 57
  1. #27
    Feb 2007
    milford ct
    tape a plastic cap over the relief valve . we had a rack problem simler to this and we found out that the relief valve was blowing off at night . and we traced it back to a faulty hold back valve
    If a Ram is a Sheep, And an Ass is a Donkey, Why is a Ram in the Ass a Goose?
  2. #28
    Sep 2011
    Tampa, FL
    Quote Originally Posted by bacciagalupe View Post
    I did 2 weeks ago and its still there. . This leak is driving me crazy....
  3. #29
    Quote Originally Posted by rackguy813 View Post
    Well, it sounds as if you might be onto it.
    I remember the last head scratcher like this that I had to deal with.
    Frozen rack lost about a thousand pounds or so before we pinned the leak down. 7/8" liquid line cracked in the ceiling above a department.
    I showed up one morning with a couple of ladders and a man-lift on the way.
    Manager asked me about this yellow, oily stuff dripping out of the ceiling.....
    Found it.
  4. #30
    Sep 2011
    Tampa, FL
    I wish the Manager would ask me if it should be leaking a yellow liquid. I would probably give them a hug lol
  5. #31
    Sep 2011
    Can you not kill the exhaust fan in the machine room and see if the machine rooms leak detector picks up a leak if the ppm were to skyrocket. You could at least eliminate the machine room or narrow it down this way.
  6. #32
    Nor-Cal
    Its a pain in the ass to cut and pinch to isolate the circuits, but if its really that bad you cant trust a ball valve, they really do leak alot more then you are familiar with- I hope you have used your new leak detector on that system top to bottom first. Remember shut off all air movement that you can. Also you might consider if you can to raise head pressure (300psi) Shut all off, take a plastic tarp and cover the condenser (like a tent), and leak check the condenser under a high pressure in a enclosed cover. I have found many big leaks that way GOOD LUCK
  7. #33
    Sep 2011
    Tampa, FL
    Quote Originally Posted by Milk_man83 View Post
    This is a rooftop mounted rack. No house just panels. No leak detection system in there at all. Eliminated rack and condenser. I showed up in the middle of the night and shut all dehumids and a/c's off. Got a hit on circuit 2. Cutting line and nitro testing now. Now that's my second confirmation that circuit has a leak. First was yesterday when I tried to pull a vacuum and couldn't break 1000 microns. Cutting out insulation on both liquid and suction lines and gonna find and finally fix this thing today.
  8. #34
    Sep 2011
    Tampa, FL
    Quote Originally Posted by Hard4mrkts View Post
    I really like this idea. Will def keep in mind the next time I'm in a position like this one.
  9. #35
    Jan 2006
    DFW Metroplex
    Does the rack have water reclaim? I've seen refrigeration lines leak inside the tank - you'd never pick it up with a leak detector unless you popped the tank relief valve and leak checked the vapor escaping with the water...
    "The problem is the average person isn’t tuned in to lifelong learning, or going to seminars and so forth. If the information is not on television, and it’s not in the movies they watch, and it’s not in the few books that they buy, they don’t get it" - Jack Canfield
  10. #36
    Oct 2009
    WI
    FTW!
    Shut down RTUs and raise head pressure. You will find that pesky leak
  11. #37
    East Coast
    Hard4markts is right. Don't trust ball valves as far as holding nitrogen away from refrigerant, just asking for trouble doing it that way. Cutting and pinching is a pain in the ass but is the best way to do it. Depending on how many vacuum pumps are in your van you could also pump multiple systems down, pull vacuums and see if they hold. If you want to make sure the ball valves aren't leaking refrigerant by(one reason why you wouldn't pull or hold a vacuum); hold a lighter to the outlet of the vacuum pump and see if you smell phosgene. Have you found this expensive leak yet??
  12. #38
    Dec 2010
    new jersey
    Quote Originally Posted by lovetowork View Post
    I have never thought of checking the gas from the vacuum pump to indicate leaking ball valves...
    I'll give it a try next time I'm in that situation.
  13. #39
    East Coast
    Lighter works well if you don't have a leak detector right next to your side.
