Results 1 to 7 of 7
Thread: UNIT SIZE?
09-27-2011, 12:55 PM #1
- May 2005
- 35
UNIT SIZE?
Aside from the compressor name plate and NO TXV, how else can you find out what size a packaged unit is w/o a unit name palte?
09-27-2011, 01:31 PM #2
- Mar 2011
- Central Florida
- 564
I've seen some evap coils with production quality control sticker telling the coil size. Other than that IF you have serial number you can call the supplyhouse even without model# and they will tell you.
I guess if you have a metering device you may try calling the supplyhouse with the metering device size to see if they can "come up with something" but its really as good as guessing by the size of the house (not too good).
09-27-2011, 01:32 PM #3
Professional Member*
- Aug 2007
- Northern VA 38 degrees N by 76 degrees W
- 3,251
09-27-2011, 01:38 PM #4
- Mar 2011
- Central Florida
- 564
09-27-2011, 01:39 PM #5
- Mar 2011
- Central Florida
- 564
BTW, why do you need tonage of system? if you don't mind.
09-27-2011, 08:35 PM #6
- Dec 2005
- 1,655
If the unit lost all tags, then it must be old.
If just to repair it, then who cares what size.
If replace it, then you best to use the "Better guess" called "load cal"
09-27-2011, 08:57 PM #7
- Mar 2011
- Central Florida
- 564
