Results 1 to 13 of 19
09-24-2011, 12:14 AM #1
Trane Clean Effects with Coleman Communicating Furnace
Is there a way to run the Trane Clean Effects with a Coleman CP9C with a communicating control? Tech support was not much help. The problem is that the 4 communicating terminals dont support the W and G from the Clean Effects in order to sense when to start doing its job. And I'm pretty sure (I dont have power yet) that the main terminals wont energize G and W when the communicating stat calls for either (otherwise I could just hook it up standard and be done with it). One Idea was to run the EAC terminals on the board to a transformer and run C from the Clean Effects to one side and G and R from the Clean Effects to the other to essentially use the blower as a switch to turn on the Clean Effects (EAC is only energized during fan operation). I dont like this idea and would rather just use a non-communicating stat. If at all possible I want the Communicating stat for my customer but its looking grim.
-Alfred E Newman
09-24-2011, 01:35 AM #2
Professional Member*
- Feb 2009
- Portland OR
- 1,506
While I don't have experience with the Coleman communicating I know my technicians have tried this on the Trane communicating to wire in an HRV and it screwed up a lot of stuff. Wy not just put in the Trane XC95M furnace instead?
09-24-2011, 01:49 AM #3
My customer was hung up on the 98% rating and would not go for 95%. I wish we had an XCM up in there! They should manufacture these communicating furnaces where the stat still energizes the relevant, non communicating terminals on the board. This would save a lot of headache
-Alfred E Newman
09-24-2011, 01:55 AM #4
- Feb 2009
- Portland OR
- 1,506
09-24-2011, 05:38 AM #5
LibertyTree. You have the post count, apply for pro membership. This is the type of question that should be asked in the pro forums. Not the AOP forums.
09-24-2011, 07:53 AM #6
09-24-2011, 08:03 AM #7
09-24-2011, 07:34 PM #8
All of the Clean Effects are communicating, the brown wire is the data wire. If I run the Coleman in 24v mode it cuts out several stages of modulation (as far as I know, I'm not super well versed with it) and I really want to make the Clean Effects work with the communicating feature.America; first we fight for our freedom,
-Alfred E Newman
09-24-2011, 07:36 PM #9
09-24-2011, 07:44 PM #10
09-24-2011, 09:06 PM #11
09-24-2011, 10:34 PM #12
09-25-2011, 07:48 AM #13
